excessive crankcase psi
Old Jul 26, 2013 | 12:57 PM
rick1542's Avatar
rick1542
Veteran: Marine Corps
Default excessive crankcase psi
Does anyone know if excessive crankcase psi cause an engine to bog and ultimately stall?
Old Jul 26, 2013 | 01:15 PM
DansYellow66's Avatar
DansYellow66
I would say that a high level of positive pressure in the crankcase itself would not cause bogging or stalling - but the mechanical conditions creating the high positive pressure in the crankcase possibly could if serious enough.
Old Jul 26, 2013 | 01:30 PM
Donny Brass's Avatar
Donny Brass
C2 of Year Finalist (track prepared) 2019
2017 C2 of the Year Finalist
I don't know enough about the crankcase venting on a '63 to say for certain, but when I fried the rings out of my 66, it puked oil like a college freshman at 3000 RPM and above, and it never stalled..........
Old Jul 26, 2013 | 01:43 PM
AZDoug's Avatar
AZDoug
C1 of Year Finalist (performance mods) 2019
2017 C1 of Year Finalist
No. You could have 1000 PSI inside the crank case, and as long as the seals didn't blow out, it wouldn't make any diff. Of course ignoring increased friction from pushing compressed air around vs atmospheric air.
There is no net change in crank case volume during running vs stopped, so no difference.
Doug
Old Jul 26, 2013 | 03:32 PM
Frankie the Fink's Avatar
Frankie the Fink
Army
Yup. Excessive blow by is one source of crankcase pressure.
Old Jul 26, 2013 | 06:18 PM
Westlotorn's Avatar
Westlotorn
I saw a 427 that had excessive blow by, it would actually blow the valve cover out.
Found out the cylinders were bored wrong on a recent "rebuild". The rings would not seat on the poor cross hatch finish. It actually ran perfectly but had smoke and huge blow by.
It took a new hone and new rings to fix.
Old Jul 27, 2013 | 09:56 AM
rick1542's Avatar
rick1542
That answers my questions, I have none of these problems. Thanks for the help
To excessive crankcase psi
