K O Wheels question
Old Jul 26, 2013 | 09:40 PM
Oaker57's Avatar
Oaker57
Default K O Wheels question
Does anyone have any pics of, or any information about the small retaining pins that go in the small recess holes inside the spinner caps, to lock them in place. I just purchased a set of Kelsey Hayes repo's, and the seller nor I knew anything about the pins untill I just heard they exist.
Any info would be appreciated.
Old Jul 26, 2013 | 10:01 PM
Velox's Avatar
Velox
These are only found on repro KOs, original KH KOs did not use these. Some repro KOs have them, there are notches on the spinner and notches on the adapters and after spinner is tight then you line up the closest fitting notches and slide one of the pins in. These are supposed to add a little security for the spinner not getting loose. That is another thread topic not worth getting into with this one. Anyway if you want to put them in, these pics show how
Here's the adapter with notches, pick one, line it up with spinner...
Here's the pins, they are available at the usual vendors like LICS...
Here's the spinner, line up one of the notches with one on the adapter...
Here what it looks like installed, pin slips all the way into notch, trim it if needed...
Old Jul 26, 2013 | 10:04 PM
65GGvert's Avatar
65GGvert
Volunteer Vette in Knoxville sell them for $2 ea plus shipping. If you'll call them and ask them to put them in an envelope the shipping is cheaper. Or you can pick them up at any Corvette vendor. Or you can make your own out of nails, or the correct size pop rivet. Or you can leave them out if the wheel is properly installed. If the wheel isn't properly installed, they won't do you any good anyway.
Old Jul 27, 2013 | 12:07 AM
Oaker57's Avatar
Oaker57
Thanks for the reply guy's
I have only had them on the car for 2 weeks, and nothing has come loose to date, so I'm assuming they are on correctly.
But upon hearing about the pins I was just curious as to what they were all about. I suppose it sure cant hurt to have them in.
Thanks again for the info.
Old Jul 27, 2013 | 07:36 AM
DansYellow66's Avatar
DansYellow66
I replaced my pins with hardened split roll pins from the hardware store. Since the aluminum pins have a slight taper to them I carefully ground one end down a little bit so they would slide in OK. Many have questioned if those aluminum pins could possibly provide much resistance to looseniing as a safety factor. I don't see that possibly being an issue with hardened roll pins. But, if the wheels are in good shape and installed properly you should not have an issue with them loosening.
Old Jul 27, 2013 | 12:52 PM
Oaker57's Avatar
Oaker57
Dan, the hardened split roll pins sound like a good idea, I will look into that.
One other question that nobody touched on, getting them out?? I assume you can just grab them with a pair of needle nose pliers?
Also assuming that they don't go all the way in flush so that they can be grabbed by the pliers??
Old Jul 27, 2013 | 01:05 PM
65GGvert's Avatar
65GGvert
That's correct. If you put them in flush or break them off, you'll have to do some drilling. I have the aluminum ones in mine just because they're not expensive and it doesn't hurt to have them, and they can be drilled easily if anything does happen. I also put a small dot with a magic marker on one of the vanes of the wheel aligned with one of the spinner bars so I can occasionally look to see if there's been any movement. It's been almost two years and no movement yet.
Old Jul 27, 2013 | 01:20 PM
Oaker57's Avatar
Oaker57
Good idea with marking them, beats the heck out walking around and grabbing them by hand every time you want to check em'
Thanks for the tip.
To K O Wheels question
