1965 L76 engine
Old Jul 30, 2013 | 11:54 AM
McGurk's Avatar
McGurk
2nd Gear
Default 1965 L76 engine
Can anyone tell me why the 1965 Corvette with a L76 engine had a Holley List 2818-1 carburetor?
Old Jul 30, 2013 | 02:10 PM
Scott Marzahl's Avatar
Scott Marzahl
What is wrong with a 2818-1? It is all that's needed for the motor.
Old Jul 30, 2013 | 02:14 PM
JohnZ's Avatar
JohnZ
Because it was designed that way - what's the issue?
Old Jul 30, 2013 | 02:16 PM
CP64365's Avatar
CP64365
Do you have a date code for the carb. Depending on the date code, the 2818-1 is most likely a service replacement carb. If it was just a 2818, again depending on date code, it is more likely to be an original carb. The date code for a 65 should be a 3 digit number under the 2818-1? Is this the type information you were asking for?
Dave
Old Jul 30, 2013 | 02:27 PM
MikeM's Avatar
MikeM
I see this is your first post. Are you just testing the waters?
Old Jul 30, 2013 | 03:13 PM
midstyle's Avatar
midstyle
Dave
Here's one off an early '64. 3A3 = 1963; 3rd week of November. The date code without the dash were early '65s only. I've seen 2 examples of 482's [ August '64, 2nd week] (without the dash).
v
To 1965 L76 engine
