oil filter leaking
Old Aug 1, 2013 | 04:21 PM
Babaron's Avatar
Babaron
Default oil filter leaking
Just changed my oil and filter on my '67 L71 and when I started engine, oil poured out from filter. Redrained and refilled but same result even though I tightened filter housing as hard as I could.
This is my first oil change and I did put the new gasket in.
It wasn't leaking before I removed it. The old gasket was there and I removed it. I placed the new gasket on top of the filter housing and pushed it up against the engine as hard as I could and tightened the bolt. Where did I go wrong? A 20 minute job is now an all day job and still not done.
Old Aug 1, 2013 | 04:33 PM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
You can't install the gasket by placing it on top of the filter housing. It will not seat into the block. You need to seat the gasket into the block first. I usually put a couple of blotches of vaseline on the top of the gasket and seat it up into the block. Carefully tighten the housing up against the gasket. You will get the hang of it. It only took me 42 years
Old Aug 1, 2013 | 04:34 PM
JohnZ's Avatar
JohnZ
That usually results in the square-section O-ring seal getting mis-located when you push the canister up. You should install the seal directly into its groove in the block first, making sure it's properly seated, THEN install the canister and filter assembly, and it doesn't take much torque on the center bolt for a dry installation.
Old Aug 1, 2013 | 04:40 PM
Babaron's Avatar
Babaron
OK, thanks, guys. I'll go give that a try and report back.
Old Aug 1, 2013 | 05:30 PM
Babaron's Avatar
Babaron
SUCCESS!!!! Thanks!!! Lacerated gasket... was the problem. Put old gasket back in (to block, as suggested above) and VOILA!!! NO LEAK!!
To oil filter leaking
