65 Brake light out
Old Aug 2, 2013 | 12:33 AM
solidaxel's Avatar
solidaxel
Default 65 Brake light out
The passenger side brake light will not work BUT the turn signal works fine, running lights and left brake light also.
I disconnected the steering column plug thinking it was not making contact but that did not help when I plugged it back together.
Where to go next??
Old Aug 2, 2013 | 01:25 AM
MasterDave's Avatar
MasterDave
Moderator
Take the bulb out and do a continuity test on each contact on the insert. If it's ok then check the bulb and then the bulb to contact surface.
Old Aug 2, 2013 | 03:51 AM
anyChevy's Avatar
anyChevy
Sounds like the switch to me.
You can try pulling the wheel off and drowning the contacts with WD40, which has worked for me several times.
They get gummed up with dry grease and corrosion.
If that doesn't work, buy a new switch.
Old Aug 2, 2013 | 07:43 AM
65GGvert's Avatar
65GGvert
If the turn signal works, you have a good wire, connector, bulb, and ground. The problem is almost certainly in your turn signal switch. The contact in the switch should make for the brake light when the signal lever is in the center position and your's is not. Hold the brake and wiggle the lever to see if the brake light flickers or comes on. As said, you may be able to clean or adjust the contact to fix it instead of replacing.
Old Aug 2, 2013 | 08:50 PM
gman1001's Avatar
gman1001
Sorry for hijacking thread, but my question may be relevant to the poster here. Steps to pulling steering wheel? Any gothyas?
Old Aug 4, 2013 | 03:49 PM
solidaxel's Avatar
solidaxel
Thanks GUYS, I should read everything before I continue with the forum!!!!!!
Old Aug 4, 2013 | 04:32 PM
solidaxel's Avatar
solidaxel
Well to report back............ A little bit of maintenance on my switch, from last post until this one it is F I X E D !!
Now replace the steering when and all screws and bolts the other half of R & Replace!!
Thanks again for the info
To 65 Brake light out
