62 steering wheel replacement
Installing a new steering wheel and the ? I have is when clocking the wheel to the hub where does the spoke facing down fit the hub in relationship to the two roll pins on the bottom of the hub? Also has anyone used the rivet replacement kit from the Corvette vendors that use threaded bolts to replace the rivets, Not to much room to install the nuts along side the hub.
Billy
Billy
The steering wheel spokes should be at 10:00, 2:00 and 6:00 respectively.
The main shaft nut should be torqued to 25 ft/lbs.
Billy
Billy
Thanks for the info Frankie, The hub has no room on the back side to put a nut on the six steering wheel screws unless I grind off a small area to allow the nut to set flush when torqued down. Are there more than one type of hub on the C1s? I will pay a visit to the local fastener store tomorrow to get the screws you have suggested.
Billy
Billy
Find the smallest screw/nut combo you can with a nut that will fit all the way down in the 'well' of the hub. It doesn't even need to be able to turn at all..just has to sit flat down inside the piece.
Then, what I did was get a long socket and straight driver on the nuts down in the hub and just '****' the tool on the nut to hold it tightly and use the screw on the OTHER side to torque things down. I'll bet you could even put a flat screwdriver down in there to jam the nut while you tighten the screw. More than one way to skin a cat.
