Media Blaster
Old Aug 8, 2013 | 05:13 PM
PierreOlivier's Avatar
PierreOlivier
Default Media Blaster
Hi,
Can anyone recommend an experienced media blaster for my 1965 Convertible.
I am located in the San Fernando Valley, CA (West Hills).
Thanks in advance.
Pierre
Old Aug 8, 2013 | 05:24 PM
Mike Geary's Avatar
Mike Geary
Originally Posted by PierreOlivier
Hi,
Thanks in advance.
Pierre
If all else fails, check with your local municipal airport to see who repaints private planes.
Plastic media blasting was originally develped for the tender aluminum skins of airplanes.
Old Aug 9, 2013 | 12:58 AM
PierreOlivier
Originally Posted by 65hihp
Hi Pierre
if you need parts media blasted, then the best place for that nearby to you is J and P Precision Deburring on Alabama in Chatsworth. Tumbling and blasting. They do corvette parts all the time, and all other automotive parts.
If you are talking about blasting your frame, then I will have to get back to you.
Don
I need the body media blasted inside and out. I need the frame sand blasted and want it to be powder coated. I got a quote from a local company Ajax - "The frame to sandblast and powdercoat a simi gloss black would be $600". Seems pretty reasonable. Has anyone out there used them? The owner indicated they have done a few corvette bodies. I am obviously concerned about the lack of experience.
Old Aug 9, 2013 | 02:23 PM
Boyan's Avatar
Boyan
Default media
I would avoid media blasting as it tends to soak up paint...call me and we can discuss options near you.
Boyan
818 517-5016
Old Aug 9, 2013 | 07:30 PM
PierreOlivier
Boyan
818 517-5016
Thanks Boyan - will give you a call Saturday (if that is ok)
To Media Blaster
