Watchout what you download
![](/forums/images/ranks/11k.gif)
![](https://www.corvetteforum.com/forums/images/ranks/veteran_army.png)
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
Wow - I do this stuff for a living and wouldn't give some of the advice provided here. I think the OP needs to let the computer fella do his thing and then set her up with proper safeguards. Its a jungle out there...
Install malware, reboot system, install microsoft, enable system restores, dont' uninstall important programs, UBNTU, it's free, easy to install, turn on computuer but I only have 10 seconds to decide, keep windows on drive C, files on drive D, comp on E, wipe C, D and E ok, save all data in secondary programs, download zipper file, it does not work, use another computer, don't boot to much, install virus program, scan with restore, disabled, MS no good use ANG.
Sorry guys, just having a little fun. I will be calling the computer man and I really do appreciate your help but I'm lost..
![](/forums/images/ranks/7k-10k.gif)
![Smile](https://www.corvetteforum.com/forums/images/smilies/smile5.gif)
"My car is overheating, what should I do? "?
A) Put Seafoam in, it cures everything.
B) Make sure your vacuum advance is on manifold vacuum.
C) Paint your valve covers and check your fan belt tension.
D) Put Marvel Mystery oil in, it cures everything else.
F) Install a Flexlite fan, the factory fans are junk.
G) Install a Flexlite fan AND SPAL electric fan, the factory cooling system is junk
H) (way down on the list), read the service manual, and probably be prepared to replace the 40 YO radiator)
WYSIWYG. Unless you are a professional in the industry that can sort the wheat from the chaff, you get all sorts of info, that may be useless, useful, or dangerous. :0
Doug
Setting up a computer protection scheme is almost like the "what oil is best" threads on here. Your computer guy (or gal) will have his own preferences which you should prob adopt if you will use that person for support in the future. I would invest a hundred bucks or so into an external hard drive and some free backup software - some products have made it so simple now its a sin not to use it regularly.
Over the years I had gone from total paranoia and multiple defenses to a very simple scheme using two products (both available in free versions) that have not let me down for general use. Never been hacked or had other than the usual spyware that was automatically eliminated by the products.
My business environment and internal LAN/WAN are locked down with obscene levels of security and system logging that I won't go into here of course
![Thumbs Up](https://www.corvetteforum.com/forums/images/smilies/thumbsup.gif)
![](/forums/images/ranks/1k-2k.gif)
I agree Frankie. I'm in the business as well. You have to be VERY careful when you're trying to get rid of a virus. If you're not careful you can make matters worse.
I have a foolproof way of preventing infections. Here it is. I store all my important files on a separate hard drive with no operating system. I then use the main system as everyone else does. As soon as my system starts to act infected. I disconnect the hard drive with all my important files, unplug the laptop or desktop, take it out to the garage. This is the important part.
I then take a small sledge hammer and bash the crap out of the computer and buy another one
![Big Grin](https://www.corvetteforum.com/forums/images/smilies/biggrin5.gif)
Uh...not foolproof if the hard drive is connected to the main system....existence of an OS is immaterial if this is the case. If the hard drive is disconnected that's called an 'air gap' scheme and a legitimate security protocol.
You guys seem to think that a fix requires some guru performing magic at assembly level.
This no longer is the 90s, really wasn't kidding about the 13 year old.
Right - that is why every major company and gov't entity in the world pays megabucks to run IT help desks.
![](/forums/images/ranks/3k-4k.gif)
#34
I retired as a Senior Executive after working my way all the way up from a blue collar gov't job in an airplane hanger. I know all about it...
#37
#38
Wow has this thing gone off the rails...anyway I was a gov't IT 'puke' for decades. Got launched off aircraft carrier decks, helicoptered out to ships at sea, did night ops training with the Marine Corps, and, bolted together F-14/A-6 avionics in a hot nasty hanger. As a CIVILIAN.
Not all gov't folks ride desks...
#39
This thread got me thinking. I have a rental house in which I had a plumbing problem this past weekend that I had to fix. I'm a mechanic by trade but I usually can fix anything on a home from carpentry to electrical to plumbing. My young Asian tenant asks me "is there anything you can't fix"? I tell him "my PC". No problem "I can fix that for you". Some things are just better left to a professional.
![Smash](https://www.corvetteforum.com/forums/images/smilies/smash.gif)
#40
![](/forums/images/ranks/100-500.gif)
Tom
