'63 Handling Question
Old Jun 30, 2002 | 12:12 PM
Boatingdobbins's Avatar
Boatingdobbins
Default '63 Handling Question
I have a '63 Conv. When driving it sometimes feels as though the rear axles are out of alignment. Other times it seems like everything is straight. Any ideas or tests I can do?
Old Jun 30, 2002 | 12:58 PM
SWCDuke's Avatar
SWCDuke
Default Re: '63 Handling Question (Boatingdobbins)
Need a more descriptive representation of the problem - what is the car actually doiing and under what conditions.
Duke
Old Jun 30, 2002 | 04:32 PM
Boatingdobbins
Default Re: '63 Handling Question (SWCDuke)
Sorry for the hard time describing the problem. I can feel a vibration in the drivers seat that comes and goes at higway speeds. I jacked the car up and did not feel any excess play from one side to the other. If there is nothing obvious to look for I will keep monitoring for the problem and try to link it with more specific driving conditions etc. Thx. for your help!
Old Jun 30, 2002 | 09:40 PM
waynec's Avatar
waynec
Sounds to me like a U-joint is going bad. Check to see if you can tell if it varies more with acceleration or deceleration... driveshaft U-joints are generally felt more on decel... or if it varies more with jounce (ie, the light or heavy feeling in the seat of your pants when going oner rises & depressions of the road), which changes the angle of the half-shafts with respect to the differential. Unfortunately, both these conditions alter the U-joint angle some, so it may vibrate with either.
Could be a rear wheel bearing, too... listen carefully for noises emanating from the rear on one side or the other during very slow operation (say, steady 5 to 15 mph).
[Modified by waynec, 5:43 PM 6/30/2002]
Old Jun 30, 2002 | 10:39 PM
396 RAT's Avatar
396 RAT
I would go to an alignment shop, put it on the rack
and go from there. The charge for an inspection should be minimal,
and could save you in the long run.
Old Jul 1, 2002 | 12:20 AM
14-Paul's Avatar
14-Paul
Default Re: '63 Handling Question (396 RAT)
Has the rear susp ever been rebuilt? if not, why not? mine tracked off center on occaision and when i started to take it apart, i was shocked at the rot and popped welds that surrounded the travel arms. its pretty expensive to rebuild and fix the rot etc, but what is more important, a shiny car or one that goes straight and safely at high speed?
sugestion: rebuild the whole susp and experience a new car feel that will suprise you! mine is awesome since rebuild! :yesnod:
Old Jul 1, 2002 | 08:54 AM
7vettes's Avatar
7vettes
From: If I say it's safe to surf this beach ......then it's safe to surf this beach
Does the car have Knock-Off Wheels?
Old Jul 1, 2002 | 10:44 AM
StrayDog's Avatar
StrayDog
Veteran: Marine Corps
Bring your Vette to a good alingment facility ...advise him/her of problem & have all suspension systems checked out.......also change upper & lower sterring shaft/colum bearings...they are cheap 30 bucks or so & you will be surprised how much slop & looseness new sterring shaft bearings resolve..............The Dog :seeya
To '63 Handling Question
