58 Nose Replacement/Bumper Fitting
I replaced the original nose because of lots of fractures and broken sections. Damage was more neglect and abuse and not due to any front end impact. I am at the point of total frustration and I don't see any corrections which would allow me to install a "normal" radiator support cushion/shims and be able to fit bumpers. Is it reasonable to elongate bumper bracket holes in an attempt to bring things into alignment. My bumper brackets are all repro as this project did not have any when I purchased her.
Struggling with posting photo of front frame rail and fender skirt gaps on each side! Sorry, couldn't get a photo to post yet. I believe when I get the nose and radiator spt adjusted to the third arm mount (1/2" to 3/4"), my fender skirts will gap above my front frame rails (by the stabilizer mounts) about 1/4" to 3/8" higher. Does this track with some of you other folks for THAT GAP? If so, I am comfortable with panel fit and will tinker with the brackets until bumpers fit right.
--radiator support to skirts and upper support flanges pretty much a given
--radiator support to third arm mount set so a "normal" cushion/shim set of about 1/2" to 5/8" spacing is achieved. Anything more and the carriage bolts might not be long enough.
--lower baffle, baffle support and attachment holes in lower nose section are aligned.
--vertically trueness of the nose when looking at it from the sides
When I did all this, headlight bezel test fitting was nearly spot on and only very minor adjustment was needed. Wheel well profiles were very good and workable. After all seemed to be fitting exceptionally well, I felt my next task was to make the bumpers/brackets fit to this panel alignment no matter what I had to do to them. I was able to fit bumpers and the brackets by loosening all bolts and slowly tightening and shimming--real methodical effort. Things are so close that maybe a few holes could be elongated to make it that much better. So, I will now take everything back apart and get ready to do the bonding and repeat the process with the bumpers/brackets knowing it does fit if you work at it. Last thing, I follow the old rule of if you have to force it something isn't right.
