STEEEEp Gears
Old Aug 26, 2013 | 06:11 PM
Hollywood41's Avatar
Hollywood41
Default STEEEEp Gears
Doing over a 1962 X racer and find it has a 5.38 gear. I assume it is a series 4 housing. Is there a code for this or is it a dealer option? It has the P on the case.
Old Aug 26, 2013 | 06:56 PM
JohnZ's Avatar
JohnZ
No, it's a production "P" housing, but with an aftermarket gearset; if the Posi unit is original, it's a Dana, but Eaton makes a drop-in unit these days. Can't imagine a Dana surviving under the kind of use you know it got with 5.38 gears.
Old Aug 26, 2013 | 08:25 PM
midyearvette's Avatar
midyearvette
wow...anyway to drive that thing around the block just for grins before you take it apart?
that would be a real treat....
Old Aug 26, 2013 | 08:50 PM
Subfixer's Avatar
Subfixer
POSSE ZR-1 Driver
Back in the day..... My first Corvette was a 62 ex-drag car. Since it was my only car (I was 19), I made it only as street legal as it had to be.
The end result was a street racer running 4.88 gears. 4 mpg was the best it would do. I had to fill the tank every day, but with gas at .40 @ gal, it was somewhat affordable....
Old Aug 26, 2013 | 09:17 PM
DansYellow66's Avatar
DansYellow66
That's some gear set for a 327. He must have drove it like a 283.
Old Aug 26, 2013 | 09:22 PM
Donny Brass's Avatar
Donny Brass
C2 of Year Finalist (track prepared) 2019
2017 C2 of the Year Finalist
me next ! me next !
Old Aug 27, 2013 | 08:31 AM
rob1961's Avatar
rob1961
I has the same thing going on with my car. I was told it was a old drag car. I have 488 gears. I drive it around anyways. not as fun as you would think. can you just replace the center section (complete 3rd member) with a passenger car unit or are the axle splines different?
Old Aug 27, 2013 | 04:09 PM
Hollywood41
Anyone know if a 3.55 gear will work in this case.
Old Aug 27, 2013 | 04:27 PM
Hollywood41
Anyone know what the code is for a series 4 case? Or where I can research this?I think that is what I have.
Old Aug 27, 2013 | 07:42 PM
ohiovet's Avatar
ohiovet
2016 C1 of Year Finalist
1955 to 1964 center section from any full size Chevy or 1956 to 1962 Corvette is a bolt in. All the axles were the same except one is longer then the other.
To STEEEEp Gears
