1966 clock
Old Sep 3, 2013 | 10:58 PM
stc's Avatar
stc
Default 1966 clock
My clock will not work!
I do not get any voltage at the plug which goes into the clock.
Should I get a reading when I connect a volt meter to the two ports on the connector? Or do I need to connect to a ground?
Help,
Stephen
Old Sep 3, 2013 | 11:24 PM
65GGvert's Avatar
65GGvert
You should get 12v when you read across the two pins on the connector. You should also get 12v if you read from the orange wire to ground. On the resistance scale of the meter, you should get almost zero ohms on the black wire to ground. The black wire ties to the black wire in the radio connector plug and then to ground. The orange wire ties to the same point as your glove box light, courtesy lights, and other things, so if they work the fuse is ok.
Old Sep 5, 2013 | 01:03 AM
stc's Avatar
stc
Default 1966 Clock
Thanks, will follow your suggestions on Thursday.
Stephen
To 1966 clock
