Carb Issues
Old Sep 9, 2013 | 01:19 PM
mspry's Avatar
mspry
Default Carb Issues
I bought a Holley Street Avenger 600 CFM a year and a half ago and had problems right from opening up the box. The car ran poorly and after several attempts to adjust it just plain sucked. Called holley within two weeks of purchase and they were no help. I ran the car with pure high test gasoline and put a fuel filter on before and after the fuel pump. Checked the little screen in the carb as well. I finally got around to buying a rebuild kit and tore it down yesterday. NONE of my screws were tight and I am talking about the inner screws. Holley has NO quality control whatsoever period. They have a great product when its put together properly. Next time I will save myself some trouble and tear it down and check everything before I put it on. Thanks for letting me VENT.
PS Runs like a rocket-ship now!
Old Sep 9, 2013 | 01:23 PM
65tripleblack's Avatar
65tripleblack
Quick Fuel carbs are worth the extra money!
Old Sep 9, 2013 | 01:25 PM
mspry's Avatar
mspry
Wish I knew before buying the Holley but its running really good now.
Old Sep 9, 2013 | 02:39 PM
midyearvette's Avatar
midyearvette
i always tear down any street avenger before i use it, the other holley models too, however mostly the problems are with the street avengers
holley's q/c does suck.....
Old Sep 11, 2013 | 02:48 PM
mspry's Avatar
mspry
Don't know if anyone else has the problem which is the rubber hose that connects the gas tank to the fuel line. Mine is rubber and deteriorating from the ethanol gas.
Old Sep 11, 2013 | 03:06 PM
ctjackster's Avatar
ctjackster
yeah, you almost need to put that on a "replace every couple of years" cycle
Old Sep 11, 2013 | 03:10 PM
65tripleblack
....which is why you shouldn't use heater/vacuum/windshield washer hose for fuel lines.
Any generic hose rated for use with gasoline (E10 included) should be described like so:
Dayco® Fuel Line Hose is designed for use on all types of gasoline engines, except those with fuel injection. This hose specification does not meet any EPA or California Resources Board emissions requirements; and, should be used only on vehicles exempt from such emmision regulations. Note: NOT suitable for gasoline/oil mixed fuels, or bio-diesel fuel. NOT suitable for fuel injection systems.
  • Offers excellent resistance to oil, gasoline, grease, and weather
  • Constructed with a neoprene cover and nitrile tube for use with leaded, unleaded gasoline and diesel fuel
  • Meets SAE J30R7 requirements and the fuel permeation requirements of SAE J1527 Class 2 specifications
  • Made in the USA
OR
Application:
A multipurpose fuel hose that can be used a fuel line, PCV connection, emission control line or fuel return line.
Specific Fuel:
Leaded and unleaded gasoline, diesel fuel, gasoline blends of ethanol (E10), E-85 and sour gas.
Construction:
Tube: Black Chemigum (NBR)
Reinforcement: 2-Spiral Synthetic
Cover: Black Hypalon* (CSM)
Temperature Range F & C: -40˚F to +257˚F (-40˚C to +125˚C)
SAE Specifications: SAE J30R7
Goodyear EP Specifications: 580019
Length: See table below. 1.6', 2' (clamshell), 25' (spool), 250' (reel)
Brand Layline: 5/16" (7.9mm) 50 psi Fuel/Emission SAE J30R7
Made in USA Goodyear
Installation: See selection of Goodyear Engineered Products clamps and connectors
- See more at: http://www.goodyearep.com/ProductsDe....jjLVtifB.dpuf- See more at: http://www.goodyearep.com/ProductsDetail.aspx?id=17820#sthash.jjLV tifB.dpu
To Carb Issues
