Partially stripped thread. Need Help!
Old Sep 16, 2013 | 01:23 PM
colo63sw's Avatar
colo63sw
Default Partially stripped thread. Need Help!
Here’s the problem:
I was replacing the front shock on my C6. When reinstalling the upper A arm, I started the bolt in the hole, it went 1-1/2 turns of semi hard turning and I stopped, I knew it wasn’t right. The inaccessible nut attached to the inside of the box frame is now cross-threaded the first 1-1/2 turns.
I don’t want to re-drill & tap a larger size because the bolt is very special & sized to the a-arm.
I bought the right sized tap, but my fear is that as I start cutting, the tap teeth will grab the first couple of threads and try to recut the entire nut at the incorrect angle. I assume the nut is steel and I don’t like pushing threads around in steel as opposed to aluminum.
Is there a way to recut the thread properly?
Details:
C6 upper front A arm bolt.
Thread size: M10 x 1.5 pitch.
Old Sep 16, 2013 | 01:31 PM
5869vette's Avatar
5869vette
There are basically 3 different taps for each size thread.
Tapered or starter, plug and bottom.
Use the tapered tap, as it will engage the original
threads and not just the crossed ones.
Hope this helps.
Tony
Old Sep 16, 2013 | 02:20 PM
Tampa Jerry's Avatar
Tampa Jerry
Default Tap
I don't know the specific application, but is it possible to start the thread from the undamaged side? Make sure you use some tapping fluid. Jerry
Old Sep 16, 2013 | 02:37 PM
colo63sw's Avatar
colo63sw
Hope this helps.
Tony
This could help a lot. I went to Ace hardware and bought a tap. It looks tapered and definitely is not a bottom tap. I am not familiar with a plug tap is there obvious visual differences between it and a taper tap?
Thanks much.
Old Sep 16, 2013 | 03:19 PM
Plasticman's Avatar
Plasticman
http://en.wikipedia.org/wiki/Tap_and_die
Old Sep 16, 2013 | 04:31 PM
colo63sw's Avatar
colo63sw
Originally Posted by Plasticman
Wikipedia. I should have thought of that, instead of looking at google images.
Looks like Ace sells plug taps. I just ordered a taper tap on ebay.
Hope it works, (will be doing the ocassional backouts as I tap thru).
Jerry,
It is a box frame with no access to the back side of the thread. Would have been a breeze if I had access to the back side.
Thanks for the advice.
Old Sep 17, 2013 | 02:22 PM
Avispa's Avatar
Avispa
If for any reason you don't have any luck with the starting tap, and the existing threads get really badly damaged, you can use Heli Coils to repair the threads and keep the original bolt size.
Old Sep 17, 2013 | 04:08 PM
69z28&ss396's Avatar
69z28&ss396
How deep is the hole? I've die ground out stripped threads and used a longer bolt.. mind you mine was just a couple threads and neither was a loaded surface or structure. just another option..
Old Sep 17, 2013 | 04:27 PM
suntreemcanic's Avatar
suntreemcanic
Not being familiar with exactly how your frame is constructed in that area could you take a hole saw and drill a hole on the back side of the frame. Save the steel plug. Then take your tap and start it in the good threads on the back side of the threaded nut and then turn in all the way through till all the bad threads are cleaned up. Assemble your shock, if everything goes well have a competent welder weld the saved steel plug back in grind down the weld and re undercoat the area. No on will know of the repair and it will be as strong as new.
To Partially stripped thread. Need Help!
