62 hardtop side window alignment?
I just ordered some new window run felts and channels, as I plan to go ahead and tighten up everything in the door, but I must me missing something on this alignment thing. any new ideas welcome.
Russ
Edit: Corvette Central part number 281026 for the 4 bumpers.
one real puzzle to me is the way the weather-strip "block" at the top of the door post keeps the window from extending up into the tops channel. because of the way it's made, it simply can't raise up there, even if the glass was oriented parallel with the opening.
if the rubber block didn't have that little nub sticking out over the glass, then the glass could potentially raise up further, but……..?
I'm aware of the up stops, and have played with there adjustment range, but I'm finding that you really can't change the angle of the top of the glass by adjusting them individually. the first stop that hits is the one that stops the windows travel.
also, by looking from the inside of the car, the header appears to be oriented correctly in relationship to the other nearby trim. there's only 1/8" gap from the corner of the header to the door post (inside), so it can't come down any further. the latches pull down with light presure and the rear mount points all line up satisfactorily.
I don't think the desire for less than 1/4" gap above the front of the window qualifies me as ****, but I could be wrong
the windshield can't really be tilted either way without fouling up the alignment of the door post, which doesn't adjust for and aft, and is very good at the moment.We've recently become friends with a local couple who own a 58 with hardtop, so perhaps I need to go pay him a visit for an up close and personal inspection of how his top fits. in the meantime, I do appreciate any other ideas that I can check on here.
Russ
Just a caution if you are trying to compare any measurements on your friends 58 top with your 62: side rail rain gutters are shorter at the very rear back window area, 1/4 window vertical channels, header and fiberglass top are the same 57-62. Good Luck
I'm mostly interested to see how everything comes together at the front corner of the side window on his 58.
Russ
Here are a couple of shots from my '62 with it's original unrestored hardtop.
The window does not go all the way up into the top seal channel, it rests against the top inner seal, and sits just up a bit in the outer one.
As you can see, for about the first inch or two along the top on mine, it is a touch low, but after that it sits just inside the outer top seal.
Here are a couple of pics, hope they help, let me know if you need more of specific points.
Paul
Mike Coletta
all kidding aside, that is a very useful picture however. shows me a great closeup of the rubber block and how it settles into the corner there, with the window up. I figured the window didn't actually go up into the channel, as the door couldn't be opened or closed at that point, but the nub on that block still makes me wonder just what the engineers were thinking that day
.I think Mike may have saved the day in the end however. for which I am grateful. I owe ya a beer Mike
. I haven't actually gone out to look yet, but I know the curved track to which you refer, and look forward to locating said adjustment slot, and playing with it.
I'll let ya'all know how it goes
Russ
