65 clock running slow
Old Sep 18, 2013 | 08:49 PM
mallie's Avatar
mallie
Default 65 clock running slow
My 65 Coupe clock (original, not Quatz converted) seems to run slow and drifts around 10min/day...
Anyone having same issue?
Old Sep 18, 2013 | 09:23 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
Nope. Never look at my clock. I have a cell phone and a watch to tell time. Also with a battery disconnect I never worrie about setting the time.
But to answer you question I am sure the points in the clock are dirty and it just needs a good cleaning
Old Sep 18, 2013 | 09:40 PM
LSUvetteguy's Avatar
LSUvetteguy
St. Jude Donor '10
10 minutes is a lot but check the owners manual. I seem to remember there was a way to speed up or slow them down.
Old Sep 18, 2013 | 10:01 PM
19Vert64's Avatar
19Vert64
I believe advancing or going back 12 hrs effects the movement to run faster or slower
Old Sep 18, 2013 | 10:14 PM
5thvet's Avatar
5thvet
DZVette put together a nice write up on cleaning the points on the clock which you can find at http://www.lbfun.com/warehouse/tech_...C2%20Clock.pdf
If that doesn't work, just do the quartz conversion. You can do it yourself in about a half hour or so and just save the guts to the old clock in case someone ever wants the original. I converted mine to quartz about 6 years ago and its run great ever since.
Don
Old Sep 18, 2013 | 10:57 PM
bosshog8's Avatar
bosshog8
http://www.corvette.net/images/ownman-5.jpg
Old Sep 18, 2013 | 11:22 PM
65GGvert's Avatar
65GGvert
With the original clock, each time you adjust the clock it makes a small adjustment. If you keep adjusting it should eventually match up. If it's varying fast and slow, you may have to clean it up. When you set it for daylight savings time and back again in the fall, it will mess up your speed again and you'll have to start all over.
To 65 clock running slow
