Decoding my muncie
Old Sep 25, 2013 | 11:34 PM
SS409's Avatar
SS409
Default Decoding my muncie
I'm trying to figure out if I have a close or wide ratio muncie. Ive been under the impression it was a close ratio but I just figured out I have a 355 rear gear ratio, (AN stamped on case). I was under the impression it was a 370 ratio. From what I've read, the M21 wasn't available with 355 gears in a 66 L79. The car was built in late April 66. Here's the numbers on the main case 6S120592 , (matches vin #) and 3885010. The side cover is 3884585. Thanks Mac
Pic is of the differential.
Old Sep 26, 2013 | 12:33 AM
69z28&ss396's Avatar
69z28&ss396
The case numbers match for a 66/67. Input should be 26 and 27 for the cluster for 21. Either pull the tranny, for input verification, as evindenced by one line or pull the side cover and count the teeth on the input/cluster. 21 input and 25 cluster are 20 or two lines on input. Hope this helps!!
Old Sep 26, 2013 | 12:38 AM
John BX NY's Avatar
John BX NY
[QUOTE=SS409;1585012981]I'm trying to figure out if I have a close or wide ratio muncie. Ive been under the impression it was a close ratio but I just figured out I have a 355 rear gear ratio, (AN stamped on case). I was under the impression it was a 370 ratio. From what I've read, the M21 wasn't available with 355 gears in a 66 L79. The car was built in late April 66. Here's the numbers on the main case 6S120592 , (matches vin #) and 3885010. The side cover is 3884585. Thanks Mac
QUOTE]
What i've seen in Nolands book and the ncrs guide agrees with your conclusion in a small block. 3.55= L79 and M20.
Old Sep 26, 2013 | 01:10 AM
SS409's Avatar
SS409
Thanks guys. Yea, sounds line an M-20. I'm going to be pulling the tranny next week. I'm installing a tko 600. I'll be bringing this thread back up and I'll post some pictures.
Mac
To Decoding my muncie
