Gear ratio
Old Jul 3, 2002 | 11:31 AM
timbuddy's Avatar
timbuddy
Default Gear ratio
What was the rear end gear ratio for a "65 327/365 HP.
Thank-you
cheers and beers :cheers:
Old Jul 3, 2002 | 11:45 AM
achapman's Avatar
achapman
Default Re: Gear ratio (timbuddy)
When I had my 65 327/365 it came with 4:11 but a friend of mine with the same engine had 3:70.... Its whatever the buyer checked off at the time of purchase... but then too, someone could also have changed out the rear end... so who knows.... :confused:
Old Jul 3, 2002 | 12:28 PM
396 RAT's Avatar
396 RAT
Most L76's came with 3.70's
Then the 4.11, and 3.55's.
With the 3.08, 3.36 and 4.56 being a seldom
ordered option with this engine.
Old Jul 3, 2002 | 12:31 PM
MasterDave's Avatar
MasterDave
Moderator
Do you just want to know which ratio you have? Easy to do. Put a chalk mark on your driveline (rear wheels off the ground) then turn your tire one complete revolution. Count how many times your driveline turns. Get it? :cool: :cheers:
Old Jul 3, 2002 | 12:41 PM
Guest
Guest
Posts: n/a
Default Re: Gear ratio (MasterDave)
Here's a nice ratio calculator to use.
http://www.angelfire.com/fl/procrastination/rear.html
Give it a try. It works pretty well.
David.
Old Jul 3, 2002 | 01:30 PM
tuxedo's Avatar
tuxedo
Good question and reply on calculations.
Old Jul 3, 2002 | 02:49 PM
SWCDuke's Avatar
SWCDuke
Default Re: Gear ratio (tuxedo)
As stated the standard ratio was 3.70, but there were five optional postraction ratios from 3.08 to 4.56. Give me your tach reading at exactly 60 MPH and I'll tell you the ratio, assuming that you have the correct speedo driven gear for the installed axle ratio.
Duke
To Gear ratio
