Big brake 62
#45
Are you sure it is not AP , which is 4:11 positraction Corvette for a 1961 Corvette. All 1962 Corvette differentials have codes beginning with letter ''C'', like CA, CF, CM etc. depending on the ratio. Again, I go back to the vin number and the white painted cove. This may be a 1961 RPO 687 Heavy brake and suspension car. I believe it was born this way as the axel rebound straps have not been broken.
Differential should have a casting #3789812 with a big ''P'' for positraction.
Have you made any progress on the vin # stamp?
#46
You really need to slow down.....to go fast here. The little info you give is all good, but not complete on any one area. Can you email me at jim@vettefinderjim.com your phone number?
#47
In 62 they made 14531 cars, and if this is a 62 model, the vin # would be 20867S110229. If so, this car was produced on April 24, 1962.
In either case, the complete vin # should be displayed on the frame in two locations on top of the left frame rail.
Now look closer at the differential and re-check the AB vs AP code and the casting number that is visible on the photo, but I can't read it. A February 2, 1962 differential makes sense in a April 24, 1962 production car.
#48
Attachment 47741200
Looks like both inner fenders have been replaced so is there another way to check if it's a Fuelie body?
What engine is in the car? Casting number in back of the block driver side should be 3782870 for all 1962 Corvettes. First year for 327. I am sure you know this as you have a 61 Corvette original owner car.
Also, the tach should have a 6500 redline. 340hp and fuel cars had same.
#49
look for tach cable hole in the firewall behind the distributor (f.i.), non fuel cars had a tach drive generator. in the 1961 model. Check ink stamping on the tachometer casing: is is "cable speed" or "twice cable speed"?
Look for washer cable hose hole by the rh firewall hood cable latch assembly (female latch), different on f.i. cars
#50
Had someone who knows these cars much better than me come by today and he found the evidence that you refer to that indicates this car was a big brake fuelie! Pretty exciting.
