Engine ID help
Oct 23, 2013 | 01:26 PM
Engine ID help
I have a SB with staggered bolt valve covers and F225FJ on engine pad. So, I know it's an early motor, just wondering if it's a 265 or 283 and the horsepower. Or a website with this info. Any help greatly appreciated.
CJ
Oct 23, 2013 | 01:36 PM
2016 C1 of Year Finalist
FJ with staggered bolt pattern valve covers is a 1957 283 CI 250 HP FI PG engine from a passenger car.
This info is from The Lime Book and to me indicates a very rsre engine.
The same code FJ is used on 60-61 348 CI 340 HP, SHP, 4 speed passenger cars.
FJ is Also used on 1969 327 CI , 210 HP, 2barrel manual trans, passenger car.
Oct 23, 2013 | 01:44 PM
From: I'm not doing as well as I expected, but I never expected I would
1957 283, PG passenger car.
Oct 23, 2013 | 04:31 PM
Thanks for the quick replies. That's what's so good about forums, knowledgeable folks willing to help.
So, FJ is a '57 283 ci FI PG passenger car.
Can someone explain F225. Is that the date?
CJ
Oct 23, 2013 | 05:17 PM
Quote:
Originally Posted by
40ZR1
CJ
1957, 283 cu in, 250 hp, fuel injected, powerglide transmission, in a passenger car, assembly date February (2), 25th.
The 3 digit date code (no leading zero for the month) indicates that it was assembled prior to mid January, 1960 (roughly speaking).
Oct 23, 2013 | 05:18 PM
40ZR1
CJ
"F" is the Flint MI engine plant. "2" is February and "25" is the 25th day of the month.
So the engine was assembled on February 25th, 1957, at Flint MI.
Oct 23, 2013 | 05:27 PM
40ZR1
CJ
For a Corvette Block,
F = Flint
2 = Feb
25 = 25th day of Feb which was an Monday.
Edit: looks like gbvette62 and I were typing at the same time...............
Be interesting to know the casting date from the block at right rear of the block.
Oct 23, 2013 | 06:02 PM
Thanks for the quick replies and the info provided, you guys ROCK!!!
Oh...the motor has been laying in the field since Noah was wearing short pants!
