63 corvette tachometer replacement
Old Oct 26, 2013 | 04:48 PM
Reds's Avatar
Reds
Default 63 corvette tachometer replacement
My tachometer failed last week and I obtained a new cable.
Removal from the distributer was a piece of cake but the removal
from the tack itself is something else. it seems that the cable goes
in a channel and attaches to the tach but getting your fingers in there is something else. Is there a trick to getting that end of the cable off the tach and attaching the new one?
Old Oct 26, 2013 | 05:29 PM
Bluestripe67's Avatar
Bluestripe67
Active Streak: 90 Days
Did you get just the cable or cable and housing/jacket? Dennis
Old Oct 26, 2013 | 05:42 PM
Mike67nv's Avatar
Mike67nv
2018 C2 of Year Finalist
2015 C2 of the Year Finalist
You didn’t say how you determined it was just the cable?
Assuming it’s the cable, I would try going at it like you’re doing with a small pair of piers or channel locks. If that doesn’t work, next best is to replace the ¼-20 cluster screws with 6 in bolts like described in JohnZ’s article below, and slide the cluster out a few inches.
http://www.lbfun.com/warehouse/tech_...ster%20pt1.pdf
Old Oct 26, 2013 | 05:47 PM
DucatiDon's Avatar
DucatiDon
C2 of Year Finalist (performance mods) 2019
Slide the cluster out.
Old Oct 26, 2013 | 06:01 PM
Reds's Avatar
Reds
Its the complete cable with the connectors at each end
Old Jul 21, 2014 | 07:54 PM
Reds's Avatar
Reds
I finally got the tachometer cable attached to the tack and dist. Problem, no response
from the tachometer with the engine running. give it gas and no movement. I removed the cable from the dist. and re installed twice but no difference. Outside of getting the
cable removed and reinstalled on the tach? Any other suggestions?
Old Jul 21, 2014 | 08:18 PM
Vet65te's Avatar
Vet65te
Maybe I missed it but have you removed the large brass fitting on the distributor to check the small cross-gear condition? As Mike67nv mentioned, how do you know the cable is the culprit? I've had the cross gears get stripped due to too much movement/clearance and it results in no tach reading. In one of those instances, when the cross gear (my description) got stripped, the shredded teeth dropped down and got caught between the main shaft and the lower brass bushing and it locked up and spun the distributor and that put me on the side of the road.
Mike T - Prescott AZ
Old Jul 21, 2014 | 08:58 PM
JohnZ's Avatar
JohnZ
Unscrew/disconnect the cable at the distributor end and put the end of it in the chuck of your electric drill and run your drill IN REVERSE; if the tach works, your problem is in the distributor cross gear drive. If it doesn't, the problem is in the tachometer itself.
Old Jul 22, 2014 | 11:06 AM
Reds's Avatar
Reds
Thats a good idea. I will also put a mirror behind the distributor
to see if I can see if the gears inside the distributer are turning
while I am at it.
Old Jul 22, 2014 | 11:53 AM
Pilot Dan's Avatar
Pilot Dan
If the Tach still does not move, you will have to pull the cluster and remove the Tach itself. Likely you have a stripped / worn internal gear
which is a common problem. If you have to go that route, it's not that bad a job and it would give you the opportunity to do lot's of other stuff while it's out. Pilot Dan
Old Jul 22, 2014 | 02:29 PM
Frankie the Fink's Avatar
Frankie the Fink
Army
This is one way folks 'back in to' frame off restorations...tach repair leads to cluster refurbishment which leads to new dash pads to door panels to....well...you know!
Old Jul 22, 2014 | 09:57 PM
Reds's Avatar
Reds
I tried using a dremel drill to turn the cable at the distributer end but
no results. It was on low speed but the cable turns but the needle
doesn't. Can I moved the instrument panel forward an inch or two without removing the steering column?
Old Jul 22, 2014 | 09:58 PM
Reds's Avatar
Reds
Old Jul 22, 2014 | 10:53 PM
RestoMike's Avatar
RestoMike
From: Livin' large and havin' fun in wonderful Oklahoma
Can't w/o scratching the column. What's there to gain by doing this?
To 63 corvette tachometer replacement
