67 window problems
Old Oct 27, 2013 | 07:11 PM
vdavenp802's Avatar
vdavenp802
Default 67 window problems
My 67 convertible has a problem with the driver door window.
From a full lower position it is stiff for about 1/2 turn on the crank.
After that is goes up easy. Going down is no problem either.
Door panel is off and inspection reveals no obvious areas for concern.
Any ideas.
Old Oct 27, 2013 | 08:09 PM
67vetteal's Avatar
67vetteal
With the window up, try spraying the Tracks with Silicone Spray. Al W.
Old Oct 28, 2013 | 04:01 AM
rich5962's Avatar
rich5962
With the window partially raised at various heights grab the glass and carefully move it up or down to try to locate the bind.
There are several possible causes that need to be checked.
- Front or rear channels binding due to friction or misaligned. Front is part of the vent frame assembly. There are guides for the rear sash 7 channel that get dirty/rusty and a common bind area.
- Guide arms and tracks dirty or dry needing cleaning and lubrication
- Binding window regulator gearbox and related arms
- Glass loose in the lower sash causing binding when operating
In order to determine which area (or areas) is the cause, you have to eliminate each one by one. I've found by removing the track arms from the sash, this allows you to manually move the window up and down by hand to verify operation. The result will tell you if it's the regulator or not, and if not then you can determine easier where it's binding in those other areas.
Below are some pics of a '67 convertible sideglass and channels for reference.
Rich
Old Oct 28, 2013 | 06:04 AM
Revfan's Avatar
Revfan
Subscribed... going to have to do this soon too!
Old Oct 28, 2013 | 10:17 AM
vdavenp802's Avatar
vdavenp802
Rich
Thanks Rich for the tips. I have inspected the channels and have put lithium grease on the track are fine ( no binding). Regulator seems fine, but your idea will tell me exactly where and maybe why. They seems to stick in the last 1-2 inches of travel. The channels themselves are not in great shape but the window is not loose either.
Your pictures are of great help.
Old Oct 28, 2013 | 01:59 PM
BB767's Avatar
BB767
Originally Posted by vdavenp802
Thanks Rich for the tips. I have inspected the channels and have put lithium grease on the track are fine ( no binding)...........
Here's something to consider. Lithium grease might not be the best material to use on those tracks. In time, it will harden to the consistency of peanut butter and create problems down the road. For window seat track lubrication a better choice would be a silicone based grease which will never harden. The gentleman who has serviced all my window needs for the last 40+ years tipped me off to this a very long time ago and it has stood the test of time. Good luck.
Thomas
Old Oct 30, 2013 | 05:56 PM
vdavenp802's Avatar
vdavenp802
Thomas
Thanks Thomas, I plan to take the tracks out this weekend so I can easily make the change.
Old Nov 16, 2013 | 02:21 PM
vdavenp802's Avatar
vdavenp802
Further work has determined that the channel on the vent window side is binding near the bottom. I think I'll have to take everything out to see exactly how to fix the problem.
Old Nov 16, 2013 | 03:01 PM
RK-TECT's Avatar
RK-TECT
Hi vdavenp802. Before you starting messing around with the vent window, try tightening the screws (especially the bottom screw) on the side of the door that secure the rear window channel. Even a small fraction could pull the window channel back just enough to allow free travel of the glass without binding. Of course, the vent window can be adjusted to tweak the front track if necessary... but that could throw off the alignment of the vent window frame to the windshield frame and/or convertible top. It's easy enough to try the rear channel first. I recently refurbished my vent windows with new rubber seals and triple chrome plating, so I have dealt with the trial and error adjustments of vent windows .
Just my 2 cents, Roger
Old Mar 31, 2014 | 05:41 PM
vdavenp802's Avatar
vdavenp802
I picked up this project after a very long winter and tried this first.
I loosened the top nut and the lower nut on the vent window channel.
Then I lowered the window and the lower nut moved back about 1/4".
I then tightened the nuts a bit and raised and lowered the window several times. It was/is smooth as silk. I then secured the two nuts completely and retried the window. Still smooth all the way up and down. I was surprised it was such a simple little thing. I'm very happy not to have needed to remove the vent window and all its parts.
Thanks to all that shared an idea,I think those jogged my creative juices.
Old Mar 31, 2014 | 07:33 PM
RK-TECT's Avatar
RK-TECT
Sometimes complex issues can be resolved with simple logic. Congrats on getting your window silky-smooth!
Old Apr 1, 2014 | 12:12 AM
BB767's Avatar
BB767
Congratulations on finally getting the issue resolved. Additionally I'd like to thank you for the followup post. Many times members post about a problem, then suggestions are give and we never hear back if those suggestions were helpful or not. I always like to hear "the rest of the story".
Thomas
Old Apr 1, 2014 | 05:32 AM
oldgold49er's Avatar
oldgold49er
Default Great thread
How often it is that I look on this forum and find someone who is currently doing the same thing to their car at the same time.
I spent most of Sunday PM rehanging my doors, and yesterday installed the tracks and vent window on the right side. I made a pigtail so I could run the window up and down in the newly installed tracks. I have not as yet installed the new harness. I left the assembly hardware loose(not to) and ran the window up and down so it could align itself.
I agree that silicon based grease is best. The crap from the factory hardens up(might expect that as in most cases these cars are at least 40.) The same type of grease is in the wiper motor, and can cause it to stop working.
I could use new "felt" in my tracks. especially the rear. Does anyone supply them? I think I could make some, but do not think real felt would work. It is not a woven fabric, and would not last. It would have to be a heavy woven material.
Thanks once again to this Forum for the great information and the timing could not have been better.
Old Apr 1, 2014 | 05:35 AM
rich5962's Avatar
rich5962
Good job.....It looks like you had a bind in the channel and someone didn't have it adjusted right in the past.
Just keep in mind that when you adjusted the vent channel lower pivot, or I should say when the channel found it's own "right spot", it moves the top of the vent window in or out from the windshield frame. Just make sure nothing's hitting or that the gap isn't too tight now.
Sometimes even if it seems a simple fix, it can sometimes affect other things later. The doors and windows on these are pretty tricky. I think the AIM's most extensive section is the doors and windows.
Rich
Old Apr 1, 2014 | 05:40 AM
rich5962's Avatar
rich5962
Most vendors have the felts that you need. The ones in my pics above came from Zip Products, where most of my items come from.
ZWS-113
Rich
To 67 window problems
