Manifold Question
Old Oct 28, 2013 | 06:51 PM
maggiesadie8525's Avatar
maggiesadie8525
Default Manifold Question
What was used on a 66 corvette 327/350hp intake manifold between the cylinder head for a sealant? A gasket or silicone, and if it was a silicone what would be recomended?
Old Oct 28, 2013 | 07:03 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
GM used gaskets and so would I. I would also use a little premetex ainti freeze sealant around the water jackets
Old Oct 28, 2013 | 07:12 PM
63split63's Avatar
63split63
I never use the rubber gaskets that GM did . A bead of black engine silicone works great. After it sets up I trim it off clean with a razor blade .
Bill
Old Oct 28, 2013 | 08:52 PM
Bluestripe67's Avatar
Bluestripe67
Active Streak: 90 Days
They both work well when done properly. I have used both methods without trouble. Dennis
Old Oct 29, 2013 | 03:56 PM
JohnZ's Avatar
JohnZ
This article may be helpful:
http://www.lbfun.com/warehouse/tech_...ntake_Swap.pdf
To Manifold Question
