What the ?????
Old Oct 31, 2013 | 01:56 PM
lonzoo's Avatar
lonzoo
Default What the ?????
The whole turn signal housing on my 63 turns when I try to turn the turn signal lever. What the heck causes this and how can I fix it?
Old Oct 31, 2013 | 02:08 PM
66jack's Avatar
66jack
You need a new TUBE...
http://www.parts123.com/parts123/yb....~Z5Z5Z50000050
Old Oct 31, 2013 | 02:28 PM
lonzoo's Avatar
lonzoo
Is this the main column tube or is there one inside?
Old Oct 31, 2013 | 02:40 PM
66jack's Avatar
66jack
Main column tube...
The housing ears have broken off for the turn signal bell to turn when you use your blinker switch/arm...
Old Oct 31, 2013 | 04:42 PM
65 Pro Vette's Avatar
65 Pro Vette
C2 of Year Finalist (appearance mods) 2019
Sorry but wrong, 63's don't have the ears on top. There is a small wedge that holds the turn signal housing with a screw from the back side.
part# SC-593 from Zip.
Old Oct 31, 2013 | 04:50 PM
JohnZ's Avatar
JohnZ
Correct! There's a screw reecessed into the forward side of the housing that threads into a "wedge" inside the housing that jams between the column tube and the inside of the housing to hold the housing in position on the tube. That screw is probably loose.
Old Oct 31, 2013 | 05:49 PM
ejboyd5's Avatar
ejboyd5
Here's a recent discussion on tools used to turn that pesky screw:
http://forums.corvetteforum.com/c1-a...on-column.html
To What the ?????
