Rust problems with powder coated frame
Old Nov 1, 2013 | 07:08 PM
TOM WILLARD's Avatar
TOM WILLARD
Default Rust problems with powder coated frame
I a 65 frame that I had blasted then powder coated. It has never been outside. I sat the body on the frame to do some measurements and noticed the frame had rust coming out every hole. Powder coater said bring it back but it is a complete rolling chassis and I will have to strip it down. Not sure if I should take it back to him or go some other route. Any ideas would be great. I saw this and took a two year break from my project but I need to get back on track. Thanks
Old Nov 1, 2013 | 07:14 PM
Frankie the Fink's Avatar
Frankie the Fink
Army
I used this on my '63 frame - pretty good stuff and you can get it nearly everywhere on a C2 frame:
Old Nov 1, 2013 | 07:25 PM
TOM WILLARD
That stuff looks pretty good. Do you think I should get the frame re powder coated then do this treatment to the inside. Should the powder coater did some kind of corrosion treatment before powder coating. I spent around two grand getting the powder coating done. This did include all the suspension parts though. It really looked nice when done.
Old Nov 1, 2013 | 09:02 PM
Frankie the Fink
Army
I really don't know that much about powder coating maybe others here or your powder coating 'guy' can provide the advice. I treated my frame completely with Ospho rust convertor, treated the internal frame passages as per the video posted above and followed up with the original, factory asphalt paint. A messy, dirty job but its all done now..
Old Nov 1, 2013 | 11:03 PM
Pilot Dan's Avatar
Pilot Dan
How does powder coating address the inside of the frame??
Old Nov 2, 2013 | 12:53 AM
TOM WILLARD
I just got the body off and the rust is worse than I thought. Its coming from areas that where brand new steel. I liked the look of the powder coating but I thought they treated the frame with something to prevent it from rusting. Do you you guys think I could get it coated again then do some work to the inside of the frame?
Old Nov 2, 2013 | 01:07 AM
narlee's Avatar
narlee
Is it coming through the powdercoating. If it is it wasn't done correctly. If it is coming from inside the frame that is a different matter.
Old Nov 2, 2013 | 06:02 AM
mike coletta's Avatar
mike coletta
It sounds like the rust is on the inside of the frame rails. That doesn't have anything to do with the sandblasting, prep, or powder coating, which were all done on the outside. The only way to clean the inside of the frame is to either have it dipped, or do something like Frank did. Keep in mind that you want to "convert" the rust, and not cover it up with some of the POR junk. You have to get it ALL. A powder coater, or sandblaster, will NOT get inside the frame. It will also NOT get between plate welded steel, like where brackets, etc., overlap each other. Ospho is a good product to get into tight places. It is a converter, not a cover up. Rust is converted from iron oxide to iron phosphate. I made up a spray bottle with a piece of hose, and a brass fitting on the end of the hose that sprays a a circular pattern (six small holes). When you pump the sprayer, it coats the entire inside of the rails. Just push it in a hole, and start spraying while you pull back. I usually do this during frame restoration, so that I can flip the frame, and put it on different angles to allow the material to go into all of the crevices.
You probably also have some "rust scale" that has broken loose. The best thing to do in your situation, is to try and blow as much of it out as you can. Good luck.
Mike Coletta
Old Nov 2, 2013 | 07:03 AM
Frankie the Fink
Army
Try the Eastwood stuff - it converts and encapsulates and is on sale for like $13 a can with a sprayer. Get 4 cans minimum. I used that on the '63 but I SOAKED the inside of the frame. I have 6 more cans coming to do the '61.
I'm betting there is a ton of folks running around pounding their chests about their body off/frame off restorations with powder coated frames that have rust (it never sleeps) creeping along the inside of their frames.
Old Nov 2, 2013 | 08:06 AM
BADBIRDCAGE's Avatar
BADBIRDCAGE
When I did the work on my 63 frame I sandblasted it, made the section repairs and then took it to Carolina Chem Strip. They electro chemically strip the frame, then they submerge it in an OSPHO type solution. It weeped that solution for three weeks prior to painting with Variprime followed by PPG topcoat.
Old Nov 2, 2013 | 09:54 AM
pullin-gs's Avatar
pullin-gs
DONT do this!:
In 1985 while in college, I bought a 1965 Buick GS convert. Very nice car, but it was rusting pretty bad on the body mounts, and inside the frame sections, and rear quarters. It was an Ohio "rust-belt" car.
I put my bubba hat on and cut the body mount rot away and then riveted some metal in its place and painted.
I had a big old compressed-air fire extinguisher laying around.
I filled it with used oil and thinned it down with diesel fuel.
I spayed it under the car and inside the frame holes.
I then had the car painted for $350.
I repeated the spray process one more time about a year later.
When I sold the car 12 years later there was no hint of rust.
It was my only car, and I always parked it outside for all those years. I put over 100k miles on it rain/shine/snow.
PS: I sold it for more than I had in it! Those were the days!
Old Nov 2, 2013 | 10:01 AM
biggd's Avatar
biggd
I'm not a big fan of powder coating. Anything that I ever had powder coated rusted just as if it was painted with Rustoleum. Not impressed at all with respect to rust prevention.
Old Nov 2, 2013 | 12:15 PM
KC John's Avatar
KC John
C2 of Year Finalist (appearance mods) 2019
Powdercoat is a plastic coating and if the surface is not prepared perfectly, the coating only makes a skin over the metal and doesn't stick to it. If this happens you can see how rust can form under the coating. I found this out by tightening a bolt with a washer under it on something that was powdercoated. When I removed the nut and washer, I was able to lift the powdercoating off in that area like a decal. It had looked perfect, but was not adhered to the metal in that area.
Powdercoaters will also use paint to touch up areas that don't come out right. I found this out once when I had a bird cage done. It was done with white and for some reason I used mineral spirits to wipe off an area and it took off the white in a couple of spots. I called them and they told me that some spots are just too difficult to get and they hit those spots with paint feeling that they are small and shouldn't be noticed.
Old Nov 2, 2013 | 02:45 PM
TOM WILLARD
I have been driving and calling all around all morning trying to find ospho but no luck. I will have to order it. I was hoping to coat the inside of the frame with it before it goes to the powder coater. Then maybe the eastwood stuff when it comes back from powder coating. I would love to just get it dipped and coated that way if anyone knows a place close to Des Moines Iowa. I am willing to try anything. I have been sad tearing this thing apart and finding rust coming out of every where. Even the crossmember that holds the rear end is rusty. It has all new bushings pressed in and probably will be junk when removed. Another 100 down the toilet. Thanks a ton guys.
Old Nov 2, 2013 | 04:12 PM
skids's Avatar
skids
Maybe these guys can help. Or steer you in the right direction.
http://midwestrod.com/services.asp
or here
http://www.motormagic.info/karl.htm
Old Nov 2, 2013 | 06:03 PM
TheSaint's Avatar
TheSaint
After a friend of mine painted the frame on my car he sprayed some rust prevention stuff inside the frame wherever he could access the inside of the frame
Old Nov 2, 2013 | 06:06 PM
TOM WILLARD
I found a guy to clean and acid dip the frame about 2.5 hours away. He is is going to meet me at his shop tomorrow morning. This way I can start with a completely clean frame. I am going to still make the powder coater re do it when I get it back but what would be the best thing to do with the inside of the frame before and after powder coating? Any kind of chemical to coat it that wont just burn off. I would like to paint inside after powder coating.
To Rust problems with powder coated frame
Old Nov 2, 2013 | 08:30 PM
GCD1962's Avatar
GCD1962
That is a problem. Acid dipping will remove the powder coat and will lossen the inside rust, but might create a bigger problem when it goes in the powdercoat over to cure (i.e. some residual acid drips out). The best thing to do is have the frame prepped by putting it in an oven to burn off the powder coat and anything inside the frame. When out of the over, blow out all you can from the inside and then powdercoat it. There is no reason anything should run out of the holes when it is powdercoated, Rust coming out of a hole will not damage the powdercoat.
Old Nov 2, 2013 | 10:58 PM
Dale002's Avatar
Dale002
Mike Coletta
Consider this option seriously. While there is no guarantee that you will get it all. I would agree this is the best way by far. I Used this option on my wifes 78 a couple of years ago and the frame still looks like the day i painted it. Most people don't realize how bad the rust can be inside the rails. You may want to invest into a cheat scope and inspect the inside of your rails before you process. This is why I chose to replace my frame on my currentr 62 build and will probably do the same on my 60 and 57 when the time comes.
Old Nov 2, 2013 | 11:20 PM
dmaxx3500's Avatar
dmaxx3500
what can be done to an already painted frame?
