Antenna Cable 64
Old Nov 2, 2013 | 10:45 AM
VIETNAM VET 70-71's Avatar
VIETNAM VET 70-71
Default Antenna Cable 64
I need to replace the cable. Any suggestions on the best
way and easiest way to do it.
James
Old Nov 2, 2013 | 01:48 PM
TheSaint's Avatar
TheSaint
Hi James
You should post this thread in the C1-C2 General discussion and not on the parts for sale forum
I am sure you will get more answers if you post it there
This is how i did it on my coupe:
But to change the antenna cable you have to start from the left rear wheel and pull the cable up from the front of the left rear wheel, have the cable go under the carpet, behind the left side quarter panel, under the left side sill plate, behind the left side kick panel and you are almost to the radio
If the moderator moves this post to the C1-C2 General forum i am sure you will get a lot of answers
Old Nov 3, 2013 | 08:26 AM
VIETNAM VET 70-71
Thanks for the INFO and I will REDO.
To Antenna Cable 64
