Differential/Trans Analyzer
www.thedrivenman.com
You can input your rearend number, choose a cruising RPM, input your tire size, and it gives your MPH. Go to site, click on GM, etc.
I like the snap of the 4.11, but not necessarily the high rpm's for interstate driving. The analyzer is a neat feature I thought.
Ron
Tremec uses an Anaerobic Flange Sealer and apparently they didn't use enough as it was leaking at the bottom. I cleaned it up and resealed it with permatex ultra gray silicone. One bit of advice, if and when you do get an aftermarket trans, I strongly recommend filling the trans with the appropriate fluid and check for leaks BEFORE you install it in the car, especially a midyear corvette.
put in the TKO 600 from hurst Drivelines. No waiting.
They had it at my shop in about a week.
Very nice difference.
Good luck,
Peter
