I am shopping for a new floor jack due to the Chinese made Sears unit failing. I need the low profile unit to get under the sidepipes on the car and I am going to go with Aluminum due to the weight of the others. I found an OTC unit on Amazon that fits my needs. It is USA made and has a lifetime warranty. Has anyone had any experience ordering from Amazon? Never tried ordering from them before and am unsure how they are to deal with and how they handle returns, if one is needed. Thanks for any help.
Very, very easy to work with. Returns just take a phone call, they send (via email) prepaid UPS vouchers...
How did your jack fail? I bought one of the Sears aluminum jacks about 8 years ago. I do not know if it was made in China, but the hydraulic cylinder O-ring failed after about two years. The seal was not available from Sears, if fact the jack was not even listed in their repair parts list. I took the old seal down to a local hardware and got the closest match I could fine. The jack has been working fine for the last six years.
USA made is getting very hard to find.
The old Lincoln W93642, 2 ton is a very good floor jack rated for commercial use and all parts are available to rebuild if ever needed.
Another high quality 2 ton with a lower entry height is the Compac, made in Denmark OLE 46. I can't say if either of these are available new today but if available they would be $500 not 89.00. Like you, I started with the cheap ones and traded up. The cheap ones have limited life spans.
I am out of date, it looks like Hein Warner is the former Lincoln jack. Note from 2007.
Catalog > Manufacturers > Hein Werner
Hein Werner a trusted name in Automotive Lifting Equipment is back. Brought back to the marketplace by SFA Company. The Hein Werner line offers quality products made in the USA and North America. The Hein Werner product line is a combination of equipment once manufacured by both Hein Werner and Lincoln/Walker. The new color of the Hein Werner line carries forward the the Lincoln/Walker color of blue and gold. "
It has extra high lift (over 21") is low profile, rapid pump with double pistons - I don't have a lift so I use the snot out of this one and love it. I had one of those Wally Mart jacks blow the seals out a year or so ago and dump my 61 on the ground - luckily the tires were on it and I was NOT under it (I use jack stands anyway).
Frankie,
That is a good jack. I do have an old Sears unit. I've had it for 30 years I think and it still works great. Problem is that it will not slide under the side pipes on my car. That was why I bought the low profile, aluminum jack. On top of that it is so damn heavy, like yours, it is tough to muscle around. I'm getting to old for that.
Charles
Mine failed the same way yours did. I just cannibalized it. I did a lot of checking with Sears and other places, just looking for a new cylinder for it. Couldn't find anything. Felt it was better just to get rid of it.
That particular jack has been around for probably 50 years and will never go out of date. Started out as Walker, then Lincoln, and now Hein-Warner. I have one myself. Parts will probably be available forever. Just about every garage in the country had one at one time.
My other two jacks are an old Blackhawk jack (about 50 years old) and a more recent Sears aluminum jack. The aluminum jack is good for smaller things.
The Blackhawk jack and the Walker (et.al) will securely lift just about anything you need.
I use a old orange Hein-Warner from the seventies and a Sears jack from the same time period that was made in Japan. The Sears jack is a nice piece however the Hein-Warner is even better. Here is a current Hein-Warner at a decent price, but it is heavy.
I agree ...one of the best buys on a jack these days. I bought one then another 6 months later. Heavy...but rock steady and low profile!
