Keeping Cool
Old Nov 25, 2013 | 09:33 PM
KENS78SILVERANNIV's Avatar
KENS78SILVERANNIV
Default Keeping Cool
Planning a 5000 mile trip (Corvette Caravan) next August. Installing Vintage Air in a '66 Coupe this Winter and looking to upgrade the radiator, new hoses etc. I have a 327 4 speed without air.
What's the best (biggest) radiator I can install to get maximum cooling and do I need to change brackets etc.? Recommendations? Suggestions?
Thanks!
Old Nov 25, 2013 | 09:40 PM
Hitch's Avatar
Hitch
Call DeWitts... then buy a hushmat kit and seal the firewall and floor pan area...
Hitch..
Old Nov 25, 2013 | 09:55 PM
Vet65te's Avatar
Vet65te
A couple years ago when I was looking for a replacement radiator for my smallblock 65 Coupe that was eventually going to get a bigblock, I contacted DeWitts and found that they offered an upgrade to the stock replacement smallblock radiator and this upgrade had larger tubes. Going off memory only, I think the core was the same width and height demensions but was thicker which did not cause any real issues with installation. Call it a slight upgrade but one I felt would be worthwhile when I finally added the 427.
Mike T.
Old Dec 1, 2013 | 09:16 PM
PBChase's Avatar
PBChase
I have a 67 small block coupe, 327/300hp. I installed vintage air along with a new DeWitts radiator that was a stock replacement. I have no problems with overheating unless I am in 90 degree plus heat with extended stop and go traffic. You will love the AC. Good luck!
Peter
To Keeping Cool
