Front seal replacement
Old Dec 2, 2013 | 12:00 AM
SS409's Avatar
SS409
Default Front seal replacement
I've replaced them on many cars but never on a midyear. Is this doable on a 66 coupe L-79 with the hood on the car or does it have to come off? Also, I may have developed a groove on the HB. Has anyone ever installed a repair sleeve on one? Thanks in advance. Mac
Old Dec 2, 2013 | 12:23 AM
DZAUTO's Avatar
DZAUTO
2026 Corvette of the Year Finalist - Modified
2025 c1 of the Year - Modified Winner
2024 C1 of the Year Finalist - Modified
2023 C1 of the Year Finalist - Modified
2015 C1 of the Year Finalist
Replacing the front seal on a SB and installing a sleeve on the harmonic balancer is the same for all SBs. It's a fairly easy and straight forward task.
Old Dec 2, 2013 | 12:43 AM
SS409's Avatar
SS409
Thanks Tom, just wasn't sure if this could be accomplished on a mid year without removing the shroud or the hood. I'll give it a try this week.
Old Dec 2, 2013 | 07:16 AM
DZAUTO's Avatar
DZAUTO
Depending on how easy the access is to the balancer for removal, you MAY need to remove the shroud.
Old Dec 2, 2013 | 01:26 PM
IGO200's Avatar
IGO200
I recently removed my balancer to repair the front cover on mine (which was leaking due to the bad spot welds - do a search on this for pics). You can do it pretty easily with the hood and shroud in place. With the fan and pulleys out you can get a good swing on the ratchet on the puller bolt.
Not a problem (as long as you have a good puller).
To Front seal replacement
