C2 1966 corvette
Old Dec 7, 2013 | 01:46 PM
LARRYCOOK's Avatar
LARRYCOOK
Default C2 1966 corvette
I have a 1966 corvette the motor letters are he as far as i can tell that comes back to a 1965 327 300 my car is a 327 300 66 will this be the correct motor for the car?
Old Dec 7, 2013 | 01:56 PM
856666's Avatar
856666
Please provide a picture of the stamp code and Cast Code
Do this and you will get an answer
Phil
Bluestripe67's Avatar
Bluestripe67
Active Streak: 90 Days
Welcome to the CF. Post the alpha/numeric info from the front engine pad and the casting number from the back of the block. That will tell exactly the application and what you have and how correct it is. Dennis
Old Dec 7, 2013 | 02:08 PM
66jack's Avatar
66jack
Small block 65 utilizes the 870 cast block...
Small block 66 utilizes the 174 cast block...
Old Dec 7, 2013 | 02:56 PM
JohnZ's Avatar
JohnZ
Either post a photo of the front block pad or tell us exactly what's stamped on it, and what's the block casting number (on rear flange of block behind driver's side cylinder head)? You haven't given us anything to go on.
Old Dec 7, 2013 | 03:56 PM
LARRYCOOK's Avatar
LARRYCOOK
Default 327 300 for 1966 corvette
Originally Posted by 65ggvert
he for 65 was a 250 hp manual. For 66, it was a 300 hp manual trans.
So are you saying h.e. Numbers will be right for a 1966 corvette.and he is for 65 vett also.im trying to find out if he numbers are right for my 1966 corvette 4 speed. Thanks. Im new to this and i get my 66 convertible corvette tomarrow or monday.............
And throw in some punctuation.
66 327 4 speed motor numbers ???
Old Dec 7, 2013 | 03:57 PM
65GGvert's Avatar
65GGvert
HE 65 327 Corvette 250 Base Manual 4-Brl Carter WCFB
HE 66 327 Impala 275 L-30 4-spd 4-Brl Hyd Cam, HD clutch
HE 66 327 Corvette 300 Base Manual 4-Brl Holley, Hyd Cam
HE 67 327 Corvette 300 Base Manual 4-Brl Holley, Hyd Cam
HE 68 327 Corvette 300 L-30 Manual 4-Brl Hyd Cam
HE 69 350 Nova 300 L-48 Power glide 4-Brl Hyd Cam
HE 69 350 Chevelle 300 L-48 Power glide 4-Brl Hyd Cam
HE 69 350 Camaro 300 L-48 Power glide 4-Brl Hyd Cam
Old Dec 7, 2013 | 04:14 PM
amtronic1's Avatar
amtronic1
Larry, please have an adult answer our questions, and do what JohnZ said to do. Post a photo of the front block pad or tell us exactly what's stamped on it, and what the block casting number is (on rear flange of block behind driver's side cylinder head).
Or,
Or you could
Any one of those three would be fine.
Old Dec 7, 2013 | 04:16 PM
856666's Avatar
856666
Larry,
On the passenger side of the engine there is a code stamped into the engine block - below the valve cover on the front.
Take a picture of this and post it here.
On the Drivers side of the engine behind the cylinder head but on the block there is a cast code Example B 17 6
Under the glove box of there is a plate with numbers
Take a picture of it and post it
Doing this will get you all the answers you need.
Phil
Old Dec 7, 2013 | 05:32 PM
Boyan's Avatar
Boyan
Let me try this. Larry, there are many more factors to the "correct" engine than just the suffix of the assembly stamping....your "HE" as you deacribed. There are casting numbers, casting dates, assembly dates and VIN stampings. Also, you will get 100 different opinions on what "correct" means. So , as stated above, we need more info. I know its a pain to post photos, but like others said, just give us all the numbers and we can help. The casting number of the block is on the drivers side where the bellhousing would bolt to the block. The casting DATE is on the other side.
I hope this helps all of us.
To C2 1966 corvette
