Engine suffix code '67 327 350hp a/c
Former Vendor
I've seen ht and hp on '67 350hp a/c engines, and have always thought both were correct, with the hp suffix indicating 350 hp, a/c, and ps.
I've asked this here before, but cannot find the post.
What's the correct suffix code; or are both correct?
Thanks,
George
Thanks,
George
Received 1,859 Likes
L79 with A/C & P/S = HP
The engine with the HP suffix had the water pump hub pressed to a different dimension than any other small-block (300 or 350hp), thus it had its own dedicated suffix.
Former Vendor
Thanks John,
I remembered it had something to do with p/s;
Your response is "crystal".
Would it be possible for you to scan/copy that information from an NCRS tech guide (or like reference) and email it to me?
There is a national flight judge that insists that hp is the only suffix for the 350 hp a/c cars .
Thanks again,
George
geopar@gvtc.com
Thanks again,
George
geopar@gvtc.com
Thanks John,
Thanks again,
George
geopar@gvtc.com
Thanks again,
George
geopar@gvtc.com
HP is only correct with A/C when the car also has P/S.
That judge needs to read the 5th Edition of the '67 JG; that information is in the engine suffix chart on page 102.
Received 1,283 Likes
And as always, JohnZ is on top of it. Well done John.
RON
But I guess we still have to continue responding and educating folks.
Another such "issue" is whether the pump to carb fuel line and dipstick tube on the 1967 327/350 HP cars are bare steel or chrome (like the 1966 cars). The latest NCRS Judging Guide address (some of) this issue also.
Larry
So, what happens when somebody needed a water pump ??? As far as I recall, no pump manufacturer including GM differentiated between a/c, p/s, or a/c & p/s for a replacement pump. How much more or less was the hub pressed on ??? Maybe this is the reason many people have pulley alignment problems.
