Transistor Ignition: L72 ??
Thanks for your help again.
Mark :)
Unless you're planning on having your car NCRS-judged, you're looking a a LOT of money to re-create the K66 Transistor Ignition system for very little real benefit. A properly set up Delco point distributor (.002'-.007" end play, Accel or Borg-Warner A112HP 28-32 oz. tension points) and a good coil will do the job just fine, or you can use a Pertronix unit instead of points.
I know a lot of guys like full MSD setups, but they're not really necessary; a properly configured semi-stock system will do the job. My 11:1 stock '69 Z/28 is set up as above (with points) with a stock coil and plug wires, and winds to the moon all day long with never a miss. Stock systems get a bad rap because people ignore maintaining them and figure the aftermarket shiny stuff must be better - not true.
I just completed this in Oct 2001. It is not hard. The challenge was finding the correct distributor.
Questions: I believe that the 66 L72 was available only with Transisitor Ignition. Is that correct???
Yes
Is it a reasonable plan to try to restore this part of the ignition system??
Yes however it is somewhat expensive if you are looking for NCRS correct parts.
Are there replacement TI components available??
Yes - LICS, Dave Fiedler, Dr Rebuild etc
What else will have to be changed....eg voltage regulator plus alternator???
I dont know which VR or Alt you currently have. I think the L72 used a 116368 Voltage Regulator. The Alt was # 1100696 (42 amp). It was also used on the 390 HP. I am not sure where else the VR was used.
You will also need the proper coil. TI amplifier, and TI harness.
Good Luck
john lolli
The L-72 ignition map specs published in Corvette News are as follows:
Initial advance: 8* nominal, 8*-14* range
Centrifugal: 0@900, 30@5000 (no intermediate rev spec is provided)
Vacuum: 0*@6", 15*@12"
I might argue with the vacuum setup. Unless the L-72 will idle at more than 12" this can might not be ideal, and I would suggest the '65 SHP/FI can that provides 16*@8". This vacuum can should insure that the vacuum plugger is pulled to the seat at idle to provide steady advance, which you need for good idle stability.
The idle speed is listed as 750-850, which seems low as are suggested idle speed on SHP SBs. I would think 900-1000 would provide better idle stability.
I have no plans to buy a Petronix or other electronic igntion. The single point works fine, and on a car that has low mileage accumulation, checking the point adjustment every year, and replacing them every few years is just part of the ritual of owning a sixties vintage high performance engine.
Duke
P.S. In the late eighties I sold the TI to David Burroughs for installation on the original car.
Has anyone ever come up with a viable (but reasonably priced) solution for updating (or replacing) the complete ignition system without losing the mechanical tach drive functionality?
Cheers.
http://www.sallee-chevrolet.com/MSD/...tors/8572.html
I am somewhat relieved, because I knew that going back to complete NCRS TI ignition would be very expensive and I am looking to have a driver-car yet not stray too far from originality. So it sounds like there are several very good alternatives. I will begin looking into these.
This website is excellent and your expertise is highly appreciated.
Thanks,
Mark
"I am planning to return to a fully stock ignition system on my 66 L72"
Now I guess I am confused as to just what you are trying to accomplish. If this car is not going to be an NCRS car there is absolutely no need to spend the money for a correct TI System. With that being said and all due respect -- why did you post this question in the first place ???? If you did it to find out how expensive it was going to be I understand -- that is a good reason. As I have said in my earlier post, it is expensive. The NCRS correct coil alone is $220. The harness is $100. A new board for the TI amplifier if you already have the can is $150. The correct 1111093 distributor could cost you anywhere from $100-$500 depending on condition. If you cant set up the dist yourself it will cost you another $100. The correctly dated dstributor tag will cost you $25. The magnetic pickup coil if you need it is $225. The pole piece if you need it is $120. If you dont have the TI Amp can that is another $150. The TI Can gasket is $10. A new vacuum can will run you $10-$40. As you can see it is expensive.
You might as well keep what you have if it is working for you.
The options as I see them and as others have said are 1) Keep exactly what you have now -- you did not mention any problems 2) return to points 3) Put a Mallory Unilite module inside a points distributor (just dont forget the ballast resistor) 4) Put a Pertronix module inside a points distributor 5) Use a complete MSD or Accell setup. There are probably more as others are sure to comment.
good luck
john lolli
Thanks for the link.
MSD Corvette Pro-Billet Tach Drive Distributor (1963 - 1974 Applications)
Comments?
So, my ignition system is, for the most part 'stock' and it starts and runs like hell.
[Modified by 67435animal, 5:23 PM 7/10/2002]
I had (have) a TI system in my '66 L72 (now, however, with a hydraulic set-up, soon to be returned to solids). When I purchased the car, it had a "points" coil which caused lots of higher rpm breakup. I replaced that with the proper coil and that resolved that problem. Recently, I went to the MSD system; put in an MSD Blaster coil; disconnected (but didn't remove) the TI module. I was going to go with the MSD distributor that 67 Heaven shows, but determined that the original tach drive, magnetic pickup distributor that was running with the TI would also work with the MSD just fine. That distributor had been rebuilt and recurved by Lars, and it does, indeed, work just fine with the MSD box and coil. For my backup, all I need do is disconnect the box, change the coil to the TI coil I still have, and reconnect the TI amp.
It saved me the expense of a new distributor even though the new MSD billet is "purtyer".... :rolleyes:
Jeff
Ô66. Modified L72
ÒThe Silver BeastÓ
Keep on :cheers: :seeya :seeya
You mean like this ?
Anyone here using this product?
Comments?
Yes I am using that distributor with the blaster coil and an msd box, I replaced my TI ignition and couldn't be happier. I could have done what blkblt did but decided to go with the whole package. My car starts right up and runs right up to redline without a miss.
Kurt :cheers:
You might want to check here, Have not used them
but have heard nothing but great things about them.
My K66 is the orig and has about 80k on it, still works great.
:smash: on wood!
Good luck with whatever you decide.
