64 LS Build W/ Art Morrison Chassis
Old 02-12-2014, 10:37 PM
  #81
64 Smoothie
64 Smoothie's Avatar
Originally Posted by 65silververt
So how does the flush mount glass work? You just put sealer in and that's it?
The edges and the inside get a black band very simular to the new cars and the glass is flush mounted to the body
Old 02-13-2014, 07:24 AM
  #82
biggd
biggd's Avatar
What kind of power window units are you using? I'm trying to install ***** power window units in mine now and having a difficult time. Not much room in those C2 doors.
Old 02-13-2014, 09:21 AM
  #83
Ken Sungela
Support Corvetteforum!
Ken Sungela's Avatar
Are you using curved or flat glass for the door windows? I called many places looking for curved, but found no one. Some have invested in the tooling for Camaros, etc, but no one for C2's. I'm told the tooling alone is $3-5K.
Old 02-14-2014, 10:09 PM
  #84
64 Smoothie
Electric Life
Old 02-14-2014, 10:11 PM
  #85
64 Smoothie
There are a few guys that say they can make them they want lots of money starting at 2200 and up I am going flat tinted
Old 02-15-2014, 08:29 AM
  #86
biggd
biggd's Avatar
Originally Posted by 64 Smoothie
Electric Life
Did you install them yet? How do they fit?
Old 02-15-2014, 09:11 AM
  #87
64 Smoothie
Yes there in and work very well waiting on my glass gut to cut the tinted side glass for one last fitment before sending them out to get tempered
Old 02-15-2014, 09:22 AM
  #88
biggd
biggd's Avatar
Did you get the glass to go down completely inside the door or does it stick up a little? That's the problem that I'm finding with the ***** unit. I can't get the unit low enough in the door to get the glass all the way down inside the door.
Old 02-15-2014, 11:38 PM
  #89
64 Smoothie
Yes goes all the way down
Old 02-26-2014, 09:27 PM
  #90
64 Smoothie
Getting a little closer
Had to build a new gas tank I made it so I can get the new style fuel pump and sending unit in and out. The pump setup is for a C5 came with the Supercharger kit
While I was welding I had to modify the air intake a little to fit around the fans
Old 03-04-2014, 10:50 PM
  #91
64 Smoothie
Here is some more pics of the Fuel Tank bein built
Gettin started on the Supercharger Plumbing
A lot of Fabbing and welding
Old 03-27-2014, 09:45 PM
  #92
64 Smoothie
Got the windows going up and down and they go all the way down in the door check out the video
http://s1249.photobucket.com/user/JD...c2036.mp4.html
Old 03-28-2014, 07:37 AM
  #93
biggd
biggd's Avatar
Nice, I'm still trying to get mine to work. I think I've given up with the ***** units. I may try the ones you used.
Old 03-28-2014, 10:28 AM
  #94
Joe Inama
Joe Inama's Avatar
Not a good location for the intake air. Any moisture might cause a hydro lock. Seen it before on a 2001 Zo6. Ran through a puddle and blew up the motor. Broke a rod.
Old 03-30-2014, 09:30 PM
  #95
64 Smoothie
The Air intake will be hidden inside of a panel Pics coming soon that pipe going down comes from the inner cooler air intake comes off the supercharger.
Old 07-29-2014, 12:18 AM
  #96
64 Smoothie
Well its been a long while since I posted any updates back on the Vette projectnow Sorry for the Delay
Picking up where I left off the Radiator is in to modify fit and tweek everything
Got the Battery box Fabbed up and installed Top Lef of pic gonna hide it with a fiberglass panel we made
Panel to hide battery in place and the air intake tube fabbed up
This is the piece we fabbed that goes across the bottom discharge from supercharger to innercooler
Back on the Body found a bad place in the fiberglass so cut it out to repair
Shaping up
Starting to get all the lines around the headlight doors even man this aint easy they are so uneven from the factory
More to come and I wont wait so long Thanks for all the complements
Old 07-29-2014, 12:25 PM
  #97
65silververt
65silververt's Avatar
I too spent quite a lot of time fitting the headlamps on the 63 split window. The fitment was off all over the place. Most people probably woundn't have noticed, but in my opinion it was time well spent.
Recently I was watching a show on the ID channel with my fiance'(about a man who killed his wife) and in the show he was driving a 65 Corvette that had the windshield and rear molding deleted. While i like the stainless, I was surprised at how good the car looked without it. I guess whoever built the car that was being used in the show built up the edges, then dropped the windshield in urethane like a modern car. Now, according to the show, the actually perpetrators midyear vette was his pride and joy. Once the police had enough evidence to arrest him they ended up in a high speed chase and the man wrecked his Corvette at a high rate of speed and died. I guess he needed a newer chassis with modern suspension.
Keep up the good work!
To 64 LS Build W/ Art Morrison Chassis
Old 08-01-2014, 09:31 PM
  #98
64 Smoothie
Yes I also believe all the lines should be correct but all of the early cars none of the lines were right mass production can do that back then we have all been trying to make the cars better than they were from the factory. So sad about that 65 if you look at my previous pic we did a lot of modifying to make the glass fit correctly I wish it was as easy as dropping it in urethane lol. Thanks for the complement
Old 08-01-2014, 09:47 PM
  #99
64 Smoothie
Getting the door glass tracks hidden and molded in
Got the new rear tinted glass in had to see what it looked like in place to make sure its the same as the olfd one for fit. we made the door glass the same color tinted glass they look great sending them off now to be tempered
Rounding and smoothing all the inside edges of the front windshied base so it looks good with the molding around it and even all the way around Shaping up
getting the final bodywork done inside and out of door tracks
More fitting and tweeking of the side panels its almost ready for its first coat of primer
Old 08-03-2014, 12:20 AM
  #100
64 Smoothie
Cleaned up taped up and ready for the first coat of primer finally
Finally all one color
Quick Reply: 64 LS Build W/ Art Morrison Chassis
