Sidepipe Re-Installation help please
Old Jul 10, 2002 | 12:11 PM
JL66REDCPE's Avatar
JL66REDCPE
C2 of Year Finalist (stock) 2019
Default Sidepipe Re-Installation help please
I had to replace the front bracket rivets on my sidepipes. I removed the rocker cover, the prod retainer and the side pipe cover. I then checked the assy manual and I think I have a discrepancy with the way the covers were installed so I am looking for some help. If I interpret the aim properly, the sequence is body, prod retainer (for rocker moulding), sidepipe cover, rocker moulding. Mine were installed body, sidepipe cover, prod retainer, rocker moulding.
A couple questions please
1 What is the correct sequence.
2 What is the correct orientation of the production retainer -- this piece has a slight channel that is about 3/4 wide. Does it go bottom of the channel out or bottom of the channel towards the body.
3 If my current sequence was wrong -- could there be a reason it was installed that way like ease of installation ??
Old Jul 10, 2002 | 01:47 PM
MasterDave's Avatar
MasterDave
Moderator
Default Re: Sidepipe Re-Installation help please (JL66REDCPE)
OK, this is the way it goes bro, the production retainer is loosly attached to the body and the heat covers slide up between the body and the retainer. After adjusting/tightening you install the outer rocker molding, it has a channel on the upper edge that mates with the rocker molding. Hope this helps. :cheers:
Old Jul 10, 2002 | 05:36 PM
MasterDave's Avatar
MasterDave
Moderator
Doggone it!! I must be suffering from CRS. I've been thinking all day and still get both scenarios. Gonna look tonight and get back to ya in the a.m. Crap I hate gettin' old.......... :cry
Old Jul 10, 2002 | 07:18 PM
JL66REDCPE's Avatar
JL66REDCPE
Default Re: Sidepipe Re-Installation help please (MasterDave)
Dave
I also posted this on the NCRS board. Have not got a response yet. I went back and looked again at the AIM and it still looks like body, prod retainer, sidepipe cover, rocker moulding. However what you said abut the slots sliding under the prod retainer made sense. In fact I am not sure you could slide the rocker moulding behind the prod retainer if you dont do it the way you suggested.
regards
john lolli
Old Jul 10, 2002 | 07:32 PM
Viet Nam Vett's Avatar
Viet Nam Vett
2015 C2 of Year
St. Jude Donor '04-'05-'06-'07-'08-'09-'10, '14-'15
Do I hear the sound of.....Nuts...Bolts....Fiberglass...and Brackets????
Old Jul 10, 2002 | 07:39 PM
MasterDave's Avatar
MasterDave
Moderator
Default Re: Sidepipe Re-Installation help please (Viet Nam Vett)
Not gonna take it apart, too much chance of scratching the paint. Just gonna take a look-see, I've had the sides off so many times last year youda thunk I would never forget.......oh, wait, I'm TRYING to forget!! Letcha know tomorrow.
Old Jul 10, 2002 | 10:21 PM
JL66REDCPE's Avatar
JL66REDCPE
Master Dave -- No problem I understand.
Viet nam Vett - Yup also the sound of a new 3/16 rivet tool to set aluminum rivets. Restoration Corrections is coming on line -- Ha Ha
john lolli
Old Jul 10, 2002 | 10:26 PM
Viet Nam Vett
2015 C2 of Year
You know John,
I forgot to bust his shoes last week about your new business.... But I will get him this week end...
PS: Thanks for the Cut Sheet, I received it to day..Thanks again
Old Jul 11, 2002 | 11:13 AM
MasterDave's Avatar
MasterDave
Moderator
Well, I looked up under the fwd part of the side pipe covers/trim strips and could only see the outer side of the covers and the upper lip of the trim strip. Could not see the retainer at all. This suggests that it's (1) body, (2) retainer and (3) heat shield. Then the cover trim strip slips into the upper retainer edge. Hope this helps. :cheers:
Old Jul 11, 2002 | 11:34 AM
JL66REDCPE's Avatar
JL66REDCPE
Dave
Thanks -- I had a feeling mine were wrong.
thanks
john lolli
Old Jul 12, 2002 | 02:00 PM
JL66REDCPE's Avatar
JL66REDCPE
Master Dave and others
Thank you for the research. I guess this ole man did interpet the aim correctly and mine were also installed backwards. I can undersatnd why as it looks like you need to do that to get the rocker moulding on. However I re-installed them per the aim. This is the way I installed the rocker moulding and it seemed to work fine. You slide the rocker moulding behind the retainer at the ends and the middle so that it gets started. Next start the two screws that hold the retainer on to properly align it front to back. Then just open the door and tap the rocker moulding down with a rbber mallet. Last tighten up the two screws and voila -- done. The trick was to open the door and tap the moulding down with the rubber mallet.
Thanks to everyone for their help.
john lolli
To Sidepipe Re-Installation help please
