bore/stroke
Old Dec 29, 2013 | 03:16 PM
skids's Avatar
skids
Default bore/stroke
I have a 3970010 block, 4" bore, which could be a 327 or 350. 350 stroke is 3.48. Using just a tape measure, I arrive at about 3 3/8" which is 3.375. 327 stroke is 3.25. Would the closest assumption be that this a 350 block?
This is all because of coolant out exhaust. Right cylinder head is toast, so am contemplating going with Summit's cast iron heads,
which are 2.02/1.60, 72cc, to replace 1.72/1.50, 70cc heads.
Any red flags with this idea?
Old Dec 29, 2013 | 03:25 PM
PAmotorman's Avatar
PAmotorman
what is stamped on the pad in front of the pass cylinder head
Old Dec 29, 2013 | 03:30 PM
skids's Avatar
skids
vo423fc
Old Dec 29, 2013 | 03:31 PM
JohnZ's Avatar
JohnZ
It's a 350 block, regardless of which crank is in it. 72cc heads on that block with flat-top pistons will give you about a 9.5:1 CR, or around 8.5:1 if they're dished.
Old Dec 30, 2013 | 08:39 AM
PAmotorman's Avatar
PAmotorman
vo423fc
it the stamping was the GM original a FC is a 1969 327 235HP.
Old Dec 31, 2013 | 12:10 AM
Usafstingray's Avatar
Usafstingray
If you aren't going with originality, why don't you just go with the Edelbrock or the AFR aluminum heads? They flow better.
To bore/stroke
