1956 Corvette paint code
Old Jan 16, 2014 | 11:11 PM
kkoykka's Avatar
kkoykka
Default 1956 Corvette paint code
I am finally having my 56 painted in about 2 weeks but need some help with paint codes as I have not been able to see anything online that anyone can make. I need a paint code for the venetian red for my interior pieces. I have only been able to locate some old codes for ppg and dupont but was told that with the new base coat paints those codes will not work and they are trying to match a piece of the original vinyl to paint chips in a book. I really don't want to do it that way as I don't think it will match the original red. Does anyone have a good paint code that I can use for my base coat clear coat job. I find it hard to believe that they can't make the right color with the amount of 56-57 Vettes that are restored and painted red. Thanks in advance for any help.
Old Jan 17, 2014 | 08:24 AM
Roger Walling's Avatar
Roger Walling
The problem in matching older colors is that the new pigments are a different color/tint from the older ones and will not match up to your color.
There is hope though, DuPont will make you an exact match, if you want to buy 500 gallons. (Maybe you could sell the extra to a few of your friends.)
I believe the National Corvette Restorers Society has a color that they will accept.
Old Jan 17, 2014 | 10:17 AM
66BlkBB's Avatar
66BlkBB
St. Jude Donor '13-'14-'15-'16-'17
Picked this up off of this site: http://paintref.com/paintref/index.shtml
Not sure it helps if the paint isn't manufactured the same as the old lacquer pigments/etc..
image [year] manuf model paint color
G B Y 1956 GM Corvette Venetian Red
Ditzler PPG
70694
DuPont
59388
Old Jan 17, 2014 | 02:02 PM
kkoykka's Avatar
kkoykka
Thanks for the input on this. I did get those same codes from that site and they were the codes that they told me they could not make anymore. I guess I will be trying to match the color. The car is going to be silver with white coves. I just need enough red to paint the dash pieces and steering column.
Old Jan 17, 2014 | 10:01 PM
Panama 58's Avatar
Panama 58
With so little that needs to be painted, maybe someone out there has some left over from a prior restoration that they would be willing to sell it to you. Worth a try. Good luck.
Panama58
To 1956 Corvette paint code
