Radio static Problems
Old Jan 16, 2014 | 11:12 PM
Joe Inama's Avatar
Joe Inama
Default Radio static Problems
I installed a ZZ427 in my 66 conv . The engine has factory HEI distributor and factory wires. With engine running I have static in the newly restored wonderbar radio. Help, any ideas ? thanks in advance.
Old Jan 16, 2014 | 11:21 PM
65GGvert's Avatar
65GGvert
C2's don't have Wonderbar radios. Did you install ignition shielding? There's no metal body to help block ignition noise.
Old Jan 16, 2014 | 11:36 PM
66jack's Avatar
66jack
Do you have all the Ground straps in place?
Old Jan 16, 2014 | 11:52 PM
Joe Inama's Avatar
Joe Inama
I have an engine ground strap and a frame to birdcage strap installed. Shielding will not fit around HEI. Wonderbar radio is what I had to install came with car. What action should I accomplish to remedy the situation. Thanks
Old Jan 17, 2014 | 12:41 AM
66jack's Avatar
66jack
Do you have the ground strap on by the antennae?
Old Jan 17, 2014 | 07:51 AM
65GGvert's Avatar
65GGvert
Wonderbar is the C1 radio that electrically tunes the radio stations. C2's have manual tuning (except possibly 63, never looked at one). They didn't come with Wonderbar radios and they mounted vertically, unlike the C1 Wonderbars. I think you're just using the wrong terminology due to the sliding bar to select am/fm. It's not Wonderbar if it came with the car.
As 66jack said, make sure your antenna plate is grounded below the antenna. You may have to put some sort of suppressor capacitors on the power to the radio and possibly the antenna lead. Did you use "R" type spark plugs and wires?
Old Jan 17, 2014 | 08:07 AM
Frankie the Fink's Avatar
Frankie the Fink
Army
If its a whining sound and changes with engine speed it may well be the alternator feeding through the radio's power line. The original noise suppression capacitors were mostly for AM listening. Amplitude Modulation is much more susceptible to interference than FM (Frequency Modulation). If you are getting the interference on FM then you might just have to add a power line filter - they aren't much money and Crutchfield or Amazon have many options for these.
As a little experiment you could wrap some aluminum foil around your HEI distributor with an alligator jumper to ground and see if the noise goes away or is reduced. If so then you've found your problem... As noted you need resistor plugs/wires too.
Old Jan 17, 2014 | 08:08 AM
jim lockwood's Avatar
jim lockwood
C2 of Year Finalist (track prepared) 2019
'63s could be had with Wonderbar radios. Sometime during the model year an AM-FM radio became available.
My '63 roadster has a Wonderbar.
Jim
Old Jan 17, 2014 | 11:26 AM
GCD1962's Avatar
GCD1962
Are you using solid spiral core wires? If not they should be used
Old Jan 17, 2014 | 02:41 PM
Joe Inama's Avatar
Joe Inama
Thanks gonna install the ground.
Old Jan 17, 2014 | 02:42 PM
Joe Inama's Avatar
Joe Inama
What ever GM installed on the crate motor is still installed. Thanks
Old Jan 17, 2014 | 03:49 PM
watson's Avatar
watson
One easy fix is to go to side exhaust. With a 427 and side exhaust, radio static is hardly noticeable.
Doc
To Radio static Problems
