Garage lighting
as I went thru the typical T5 T5HO T8 and T8HO fluorescents. I realized that even with these I would probably be using about 400 Watts while in the shop.
So was wondering if anyone has tried these things? Do you get a suntan? Is it like being to close to the sun lol
I can get 3 new ones for $90 a piece from a guy that went under and closed his business. I could have them on 3 different switches so burn 400watts at a time?
Dumb idea or not?
If you go the manufacturer's web site for those fixtures, they should have a photometric chart for those fixtures, that will show the cone of light that they throw, and you will see that the cone grows, the higher off the floor you go. Ideally, you want at least 25% overlap of the light cones on the floor. and I think that you would need way more than 3 fixtures to light 2800 feet with these luminaries, based on the design I see in these fixtures.
Regards, John McGraw
Hate work lights too.
http://www.daybrite.com/vandal/Vanda...re.cfm?ID=4129
Dumb idea or not?
I have these in my shop. They are very bright and only take a few minutes to warm up. I hooked them up on 110 current but a buddy of mine say they use less if they were on 220. They'll work either way. I bought mine used, so I bet new ones are very pricey. When I'm not using them, I have regular lights that I use, although the bulbs are 400 watt energy efficient bulbs that are twisted and they only use 40 watts of current. I found them at Menards but no where else. Great bulbs.
In my machinist days, our shop originally had fluorescent lighting that we replaced with the halide lighting to save money on the electric bill. I absolutely hated the halide lights once they were installed because of the shadows they would cause in front of me as I attempted to set tooling in a machine. We had the halide fixtures in place for maybe 10 years before replacing them with the high performance fluorescent available today from companies like Orion.
I'm older than 60 and I need more light than when I was younger.
I knew from experience that I only wanted florescence lights because they cast almost no shadows and the new T5 HO's are so efficient almost all our local warehouses are replacing their older light fixtures with T5 HO's for operational cost efficiencies.
In the barn we used 20 T5 HO fixtures with 4, 4' lamps per fixture and white reflectors.
This is one of the rooms in the barn and this room is over 3,500' with a 16' ceiling at the peak.
They measured after the installation and I get 78 foot-candles of light at 34" (bench height) above the floor which is more than adequate for my feeble old eyes and the light is very even throughout the room.
In specific areas...
... like this corner, I added additional lighting over the bench to help with close detail work.
I zoned all the lighting with multiple switches so I only light those areas that I'm working in.
The color of your ceiling and walls will affect how much light you need as well.
As Tom stated, you will never have enough light!
Hope the pictures help visualize what T5 HO's will do in a large space with high ceilings. Good luck with your project.
Thomas
The garage will be continually heated as it has its own furnace, hot water heater and AC unit. So I can probably use t8s without the need for an HO as it will never be below 50F in the garage.
Are your 62 & 64 cars 409/4sp cars?
Here's part of what my restored 1930's shop with 10' ceilings looks like...
... using T8's, 2 lamps, 8' long per fixture. I get very similar lighting levels as in the barn but all future lighting will be done with T5's as they operate much more efficiently.
Thomas
Thomas
