Stalling under Hard Braking
Old Jan 30, 2014 | 07:54 AM
Dicecal's Avatar
Dicecal
Default Stalling under Hard Braking
65 L-79 with 2818 carb. Under hard braking, like a panic stop...the engine usually stalls. I've checked the easy stuff like carb float levels. Any other ideas what could be causing this? I recently replaced my fuel pump (the old one was leaking oil) and it seem to be slightly worse. (but was a problem with the old pump too) Thanks in advance
Old Jan 30, 2014 | 08:03 AM
Avispa's Avatar
Avispa
Are the fuel bowl vent "whistles" in place? If the secondary bowl whistle is missing, fuel could be sloshing into the bowl vent tube and flooding you out on hard stops.
Old Jan 30, 2014 | 09:00 AM
DIP51's Avatar
DIP51
2018 C2 of Year Winner
Push the clutch in!!!!!
Sorry, I couldn't resist.
Old Jan 30, 2014 | 09:15 AM
Dicecal's Avatar
Dicecal
Find something better to do, no value added to thread.
Old Jan 30, 2014 | 09:21 AM
hedgehead's Avatar
hedgehead
From: I'm not doing as well as I expected, but I never expected I would
Old Jan 30, 2014 | 09:44 AM
DIP51's Avatar
DIP51
It did bump it back to the top...you're welcome. Geeze, lighten up.
Old Jan 30, 2014 | 09:46 AM
67*427's Avatar
67*427
Almost certainly induced by fuel sloshing over into the venturi. To prove it, lower the float level considerably (1 or more turns on the needle adjustment) and go drive the car and see how it reacts. If that fixes it (or helps), then look for a missing vent shield in the fuel bowl (I've seen that one).
My '67 had the problem on hard turns. I dropped the fuel level just a little below spec and the problem is gone.
Steve
Old Jan 30, 2014 | 11:24 AM
larrywalk's Avatar
larrywalk
Veteran: Marine Corps
Add a fuel vent whistle to the secondary side - it will cure the problem. BTDT.
Old Jan 30, 2014 | 03:11 PM
JohnZ's Avatar
JohnZ
From the secondary float bowl.
Old Jan 30, 2014 | 07:01 PM
frankturbo's Avatar
frankturbo
agreed
Old Jan 30, 2014 | 07:54 PM
Dicecal's Avatar
Dicecal
Thanks for the constructive comments, I'll take a look at it!
Old Feb 5, 2014 | 06:06 PM
Dicecal's Avatar
Dicecal
I installed these vent whistles from Quick Fuel:
http://www.quickfueltechnology.com/search?query=59-10
They press right into the metering block, and are held in place by the fuel bowl gaskets. No more problems! Thanks again guys!
Old Feb 5, 2014 | 06:35 PM
woodsdesign's Avatar
woodsdesign
This is good information. My car also stalls under hard breaking.
I also had a problem with it stalling after a hard power shift. (not that I would do that very often) I thought it was because of low fuel in the tank.
Old Feb 5, 2014 | 07:13 PM
Dicecal's Avatar
Dicecal
Yes, so much better now! The secondary vent will cure the braking problem, and the primary vent will cure the acceleration problem. That's why there are two included, use them both.
Old Feb 5, 2014 | 08:34 PM
woodsdesign
thanks for the info.
Old May 7, 2014 | 11:25 PM
BigT-65's Avatar
BigT-65
So, what is a vent whistle? Which carburetor are we talking about having these? Does a Carter AFB have vent whistles?
Old May 7, 2014 | 11:44 PM
66jack's Avatar
66jack
"The vent whistle installs in an opening at the front of the metering block and extends the vent opening toward the front of the fuel bowl, so it is unaffected by fuel sloshed to the rear of the bowl by heavy acceleration G-forces."
Read more: http://www.ehow.com/how_12112920_use...#ixzz315mAIPgT
Old May 8, 2014 | 07:38 AM
Frankie the Fink's Avatar
Frankie the Fink
Army
These whistles are for a Holley and don't apply to the Carters....totally different design...
To Stalling under Hard Braking
