1963 SWC Engine and transmission install
When I took out my engine and transmission as one unit, I had a difficult time due to my 4 speed shifter being hard to remove from the transmission. I am getting ready to install the eng and transmission now. Any suggestions that would make the process a little easier. I have nightmares thinking about putting the shifter on with the transmission and engine in the car. Would it work better to put just the transmission and shifter in and then the engine?
Thanks.
Thanks.
Received 2,127 Likes
Thanks.
Thanks.
The shifter removal/installation is a little tedious and the comment about undercar exhaust in the way is a good one. Don't know of any real options though. Just not enough room for that transmission alone to be installed - or an engine/transmission together - with a shifter attached.
