block differences
Old Feb 7, 2014 | 06:59 PM
prestige6's Avatar
prestige6
Default block differences
What is the difference between a Flint block and a Totowanda block,are there different casting numbers or is it just the front pad stampings???
Old Feb 7, 2014 | 07:29 PM
JohnZ's Avatar
JohnZ
The basic castings are the same, and Flint and Tonawanda also built the same casting numbers in many cases. The Tonawanda machining process was slightly different than Flint, so the Flint block was the only one that had a 1/8" NPT square-head plug just above the timing cover - it wasn't required on a Tonawanda block. The casting date code on Tonawanda blocks had two characters for the year, and only one character on a Flint block.
Remember that Service parts had to fit perfectly without regard to the block source - castings and machining had to be the same or there would have been chaos in the field. Same thing applied to McKinnon (Canada) "K"-prefix blocks - they all had to be fully interchangeable with each other.
Old Feb 7, 2014 | 07:51 PM
DZAUTO's Avatar
DZAUTO
2026 Corvette of the Year Finalist - Modified
2025 c1 of the Year - Modified Winner
2024 C1 of the Year Finalist - Modified
2023 C1 of the Year Finalist - Modified
2015 C1 of the Year Finalist
As John mentioned, the Flint blocks had a square head pipe plug in an oil passage above the timing cover. This passage was drilled into the middle galley in the lifter valley. The BOSS for that oil passage is in all of the Tonawanda blocks, but not drilled and tapped.
When I build an engine that came from Tonawanda, I frequently drill and tap the passage and install an oil pressure gauge so that I can read pressure right at the engine. THIS NEEDS TO BE DONE BEFORE THE BLOCK GOES TO THE MACHINE SHOP SO THAT ALL THE METAL PARTICLES WILL BE REMOVED FROM THE OIL PASSAGE!!!!
This picture shows the boss going down to the oil galley.
Old Feb 7, 2014 | 08:12 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
what application was that threaded boss for that only Flint cast it?
Old Feb 7, 2014 | 09:21 PM
327carguy's Avatar
327carguy
I think that you WILL find the plug on early 283 Truck blocks from the Tonawanda plant. I know I have.
Old Feb 7, 2014 | 09:30 PM
DZAUTO's Avatar
DZAUTO
ORIGINALLY, it was on ALLLLLLLLLLLLL 55 265 blocks for oil supply to the oil filter. An Oil filter WAS NOT standard on a 55 block (the 55 block did not even have the pad for a filter). Anyone have a picture of a 55 ONLY oil filter?
In 55, the filter was still an option, and the mounting bracket for the filter was positioned BETWEEN the thermostat opening on the intake manifold and the thermostat housing. Oil supply TO the filter came from that front hole and oil was RETURNED to the crankcase through a threaded fitting/hose on the right side of the intake manifold next to the exhaust crossover passage. As far as I know, ALLLLLLLLLL 55 intake manifolds had the threaded hole and a pipe plug was installed if the engine did not get a filter. The threaded hole was there whether or not the engine got a filter because sometimes the dealer installed a filter before delivery to the customer.
And, as mentioned, that hole at the front of the block was also used to supply oil for such purposes as the air compressor on big trucks with air brakes.
Old Feb 8, 2014 | 06:16 AM
mashinter's Avatar
mashinter
Here's the plug on a 3756519 Flint block:
Old Feb 8, 2014 | 07:38 AM
Easy Rhino's Avatar
Easy Rhino
From: Middle TN by way of KY, OH, VA, IL, CA, FL, NY, SC, HI
Wow.
I do remember those oil filter-less blocks.
To block differences
