this weekend todo list
Old Mar 7, 2014 | 02:14 PM
jimh_1962's Avatar
jimh_1962
2018 C1 of Year Finalist
Default this weekend todo list
Looks like I will have a free weekend to focus on some small things before I install the transmission and engine.
Repaint the side engine mounts, radiator shroud and fan blades.
Remove gear oil from transmission.
Clean all of the hoses and see about using the correct style clamps.
Clean chassis and underneath body.
Tighten up chassis and exhaust bolts.
Reinstall rubber on splash shield.
Reinstall rubber seals on firewall.
Fix package tray loose screw on the dash.
Check driver side brake line fittings for leaks.
Add weather grommets for the bumpers.
Clean grill, bolts and spacers.
Paint back of front license plate frame.
Check wiring on voltage regulator and check wiring for car once more.
Install the distributor correctly and coil plus route wires.
Install the ignition shielding once more.
Polish top ignition shielding.
Install the wiper switch once more.
Install the rubber pieces for the radiator.
Old Mar 7, 2014 | 05:14 PM
Gman58's Avatar
Gman58
Default Weather
I have a list to. I think it might be the weather. Aside from a some rain, which we need it's starting to get real nice out. Greg
Old Mar 7, 2014 | 05:20 PM
jimh_1962's Avatar
jimh_1962
You got it!
Old Mar 8, 2014 | 12:37 AM
SS409's Avatar
SS409
I like working off a list. You just check each item off as you go. I just got my 66 coupe back from Santini's bodyshop in Westminster Ca. today and I'll start installing the brightwork this weekend. I'm also installing a delfi 600 steering gear. I'll explain what happened and post some before and after pics in another thread next week.
Old Mar 8, 2014 | 02:09 AM
tach drive 61's Avatar
tach drive 61
If we're lucky with weather here I will change oil.and MAYBE take the 61 out. Short list
Old Mar 10, 2014 | 03:35 PM
jimh_1962's Avatar
jimh_1962
Repaint the side engine mounts, radiator shroud and fan blades. - Done!
Remove gear oil from transmission. - Done
Clean chassis and underneath body. - Done
Tighten up chassis and exhaust bolts. - Done
Reinstall rubber on splash shield. - Done
Fix package tray loose screw on the dash. - Done
Check driver side brake line fittings for leaks. - Done
Add weather grommets for the bumpers. - Done
Clean grill, bolts and spacers. - Done
Paint back of front license plate frame. - Done
Check wiring on voltage regulator and check wiring for car once more. - Done
Install the distributor correctly and coil plus route wires. - Done
Install the ignition shielding once more. - Done
Polish top ignition shielding. - Done
Install the wiper switch once more. - Done
And finally, beer time! - Done.
Now, I have to borrow an engine hoist for this weekend. Closer...
To this weekend todo list
