offset trailing arms ?
Old Mar 11, 2014 | 06:19 AM
Wayne1964's Avatar
Wayne1964
Default offset trailing arms ?
There is little information on ordering tire and rim combo for trailing arms offset . I installed 1965 ( disk ) offset trailing arms on my 1964 . I might have to buy a shorter rear spring as well .
I like the look of the Craiger 61c581242 rims with the spinner 09095-2 . I like the look of the wider tire on the back. Thanks for any help including pictures.
Old Mar 11, 2014 | 09:37 AM
Sky65's Avatar
Sky65
St. Jude Donor '05, '09, '15
I'm sure you realize wheel/tire fitment is much more involved than just trailing arm clearance. There are plenty of threads on max wheel/tire size. I suggest starting with what do you want to use and go from there.
Tom
Old Mar 11, 2014 | 10:08 AM
DucatiDon's Avatar
DucatiDon
C2 of Year Finalist (performance mods) 2019
2018 C2 of Year Finalist
I think the snubber mount and e brake cable are the first limiting factors.
Old Mar 11, 2014 | 11:29 AM
Wayne1964's Avatar
Wayne1964
Tom
Tom I will keep looking. I assume you do not have offset trailing arms. I would like to hear from those who do and any issues that came up. Pictures would be great. Don't want to re invent the wheel This is an expensive decision only to be made once Thanks
Old Mar 11, 2014 | 04:55 PM
Sky65's Avatar
Sky65
Actually I do have offset trailing arms on my 65 with 9" wide 17" rims and 275/50 tires on the rear. Also have small flares. I guess I’m trying to point out there are many limiting factors with tire/wheel changes. Just because you have offset trailing arms it does not mean you can put any wheel/tire combo you want on the car. I did a search for “widest tire” on the C1/C2 forum. There are 13 threads. Lots of info. Hope it helps.
http://forums.corvetteforum.com/sear...rchid=40235474
I checked your location. If you were close I'd say come on over and look, measure or whatever you want to get what you need but Canada is a bit of a drive!
Tom
Old Mar 12, 2014 | 06:03 AM
Wayne1964's Avatar
Wayne1964
Tom
Tom that is the kind of information I am looking for. Thanks. Would love to come over but I would need to dig out of some snow.
Link doesn't work for me. My confusion is the offset trailing arms add I believe two inches. There is also a offset on the rim people talk about 4.5 inches. so the combination of the two sort off messes me up. Plus the width of the tire inflated.found this site that helps http://www.wheelwright.co.uk/knowled.../fitment-guide
Old Mar 12, 2014 | 07:45 AM
biggd's Avatar
biggd
I would say the best way of doing this is to put the offset trailing arms on first before ordering your wheels and tires. Then, with tape measure in hand, you will know exactly what will and will not fit.
Old Mar 12, 2014 | 09:27 AM
Wayne1964's Avatar
Wayne1964
Thanks I have the offsets on and will take your advise . Curently knock offs are on
Old Mar 12, 2014 | 10:06 AM
biggd's Avatar
biggd
Let us know what you put on for rim sizes and off sets for future reference. Are you going with 15" rims or upgrading to 17" or 18"? The larger rim size offers even more clearance.
Old Mar 12, 2014 | 10:11 AM
Wayne1964's Avatar
Wayne1964
Looking at 17 inch. should resolve the spring issue having to be shorter. I think I will make a cardboard templet then measure from all the edge distance that might impact tires . Thanks
Old Mar 12, 2014 | 10:14 AM
biggd's Avatar
biggd
What size off set trailing arms did you go with, 1" or 2"?
Old Mar 12, 2014 | 12:32 PM
Wayne1964's Avatar
Wayne1964
two inch offset disk brakes
Old Mar 12, 2014 | 01:56 PM
dhutton's Avatar
dhutton
One of these might come in handy:
http://www.summitracing.com/parts/php-01201
Don
To offset trailing arms ?
