Doing my spring service on my lawn equipment and decided to install e3 spark plugs in my mower. I immediately noticed a huge difference in performance and fuel consumption. So I was wondering if I might get the same results in my '66.
Now I know there's a difference between a mower and a corvette so no one needs to remind me, but they're both internal combustion engines. I also know there are those who are purists and those who will say it's an expensive gimmick, and I shouldn't waste my money. I'm interested in hearing from those who have used them in their cars.
Several years ago I installed Split Fire plugs in the 69 Corvette. I did not notice any diference. However, it ran good. I would suspect that the difference is minimal. Probably the larger the engine the less you would notice the improvement.
I am not familar with E3s.
From the e3 WEB site; Improved "Mass Fraction Burned"
This means that just a slight increase in flame kernel strength can cause a cascading improvement in the entire combustion process. By getting the flame process started earlier, the mass fraction burned at any given crank angle position away from TDC is increased. Since the exhaust valve opening occurs at a fixed point in the crankshaft's position, we understood how important it is to get as much of the fuel burned before it is vented off during the exhaust cycle. So, to increase power and reduce emissions, we created the DiamondFire electrode designed to burn more of the existing air-fuel mixture present in the combustion chamber.
It seems to me that adding a "Hotter" Coil would produce this effect. Splitting Hairs? The Lawn Mower most likely may have had an old worn out plug. But then again, a strong ignition system is critical to a good combustion. Al W.
Too bad it's not possible to advance the timing slightly which would achieve the same thing.
Sometimes changing to better spark plug wires will vastly improve your performance because a hotter spark due to old wires having a lot of resistance. Just changed my old Accel wires for MSD and the old wires had up to twenty time the resistance.
Split Fire Spark plugs were the best marketing scheme of the decade, the actual product was a detonation inducing failure, but hey, marketing told you they were great and many believed them, at least to purchase them one time. Where are they today?
Auto-lite is still around but where are those revolutionary split fire plugs? E3 falls in the same basket. If you want technology buy Iridium Plugs, they spark at the same low voltage as a copper plug but will last 20 times longer in both low voltage systems and HEI systems. Unfortunately I have not found a company releasing Iridium part numbers for these old Corvette engines, too low of volume to chase our market.
I remember multi-grounding electrodes in the '50's. I don't remember the name of the plugs. I had a Whizzer motor bike that wouldn't run. I bought it from a buddy and he assured me if I bought one of those whiz bang multi point plugs, it'd fire right up and run like a top!
If those multiple electrodes had any advantage on power and MPG, you can bet the OEM's would be all over them. But they're not!
I have to confess to having tried them in my Corvette many years ago - they were crap. Literally started causing problems within a few hundred miles. A local speed shop suggested a standard Accell plug and they have done great.
Truth be told Dan, everybody on here has gotten sucked in to trying one marketing fliz or another at some point.
That is a great article Mike, deals with facts not marketing.
Most folks don't know that Champion today is cutting edge in plug technology.
The top Teams in Nascar, NHRA, Formula One and much more choose Champion because they work. Mercedes installs Champion in some of their brand new engines because Champion Iridium technology trumped Bosch. Getting a German Engineer to move from Bosch to Champion takes a lot of convincing. Many of us remember the terrible quality Champion was selling in the 80's and they still carry a bad name from that era but today they build high quality product.
]That is a great article Mike, deals with facts not marketing.[/B]
... Champion is coming back on the map by producing a higher quality product. Unlike what they were producing in the 80's, that left a sour taste for me on their plugs.
