Headlight Y stop??
Old Jul 16, 2002 | 11:50 PM
BK64's Avatar
BK64
Default Headlight Y stop??
If I had the buckets off and made no changes other painting them should the Y stops still be in the proper postion? The reason I ask this is because the are now overshooting on close, also I had to adjust the fit with the nut on the motor. Could reversing the stops cause this? ie driver to passenger and vise versa. Thanks if this is the case I will interchange them if not I guess I will set the Y stop bolts. Thanks :cheers:
Old Jul 17, 2002 | 12:17 AM
Denney's Avatar
Denney
Default Re: Headlight Y stop?? (BK64)
Yup. If they were swapped, it could definitely affect the position.
