Rubber busing replacement
Old Jul 17, 2002 | 11:15 AM
vetzs's Avatar
vetzs
Default Rubber busing replacement
If a person replaces the rubber bushings on the suspension and/or the body mounts does that change the alignment?
Old Jul 17, 2002 | 11:25 AM
JohnZ's Avatar
JohnZ
Default Re: Rubber busing replacement (vetzs)
Body mounts won't affect it, but if the old suspension bushings were well-worn, new bushings will definitely change the alignment.
Old Jul 17, 2002 | 08:00 PM
Bluestripe67's Avatar
Bluestripe67
Active Streak: 90 Days
If you attempt to have the car aligned by only replacing, I assume, the control arm bushing this will help to show up the other worn components. Your alignment will not be the best you can get. Hope this helps.
To Rubber busing replacement
