confirming the correct original engine
Old Apr 5, 2014 | 09:39 PM
Easy Rhino's Avatar
Easy Rhino
From: Middle TN by way of KY, OH, VA, IL, CA, FL, NY, SC, HI
Default confirming the correct original engine
Archaeology commences on my new to me '65.
It currently has a 300hp 327 (HF) engine in it, but non-numbers matching (wrong vin on engine stamp pad).
Hints: It has the high rpm tach, 4.11 gears (I think, but to be confirmed), and has been repainted. It is a June 1965 build, very late for the few fuelies built in '65.
Where to look?
It has the fuelie firewall hole, but I think I read where they all did in '65, and sits high in the front (too light?).
I have not had a chance to look under the fenders for prior badges, and I see no evidence of the driver's side (BB) battery.
By numbers alone it is most likely to have been a 365hp, imho.
Thoughts?
Old Apr 6, 2014 | 07:10 AM
DansYellow66's Avatar
DansYellow66
The high RPM tach is the only hint of an original high HP SB. You could pull the instruments and see what you find on the back side to authenticate if it is the original tach or not. Does it appear to be a complete engine transplant or could any original parts have been mounted back on a short block? I would check the transmission numbers to see if they match the VIN. If it was a mechanical lifter motor originally it was probably ordered with the close ratio box - but to verify if it's CR or WR would require pulling it. You can reach some conclusions from driving it and rpm drop between shifts but I don't know that I could be sure from that alone.
I doubt anyone would have ordered a 4.11 rear with a 327/300 engine if by chance the rear differential is original and coded for a 4.11 rear.
Other than that - I would just enjoy it as a 327/300 car which is a nice driver or you can make it into anything you want.
Old Apr 6, 2014 | 08:56 AM
856666's Avatar
856666
Default Ratios
Here is a link to derive gear ratios vs speed etc.
I found it handy when deciding on a 5 speed. I ended up with a T45 aka RS400/500 and a 3:55 differential.
http://www.corral.net/tech/gearcalc.html
Phil
Old Apr 6, 2014 | 12:22 PM
gbvette62's Avatar
gbvette62
Do you mean hole in the radiator core support? If so, only fuelies had the hole in the core support, from the factory, but the GM service replacement supports all came with the hole. If the support was replaced at some point because it rusted out, or was damaged in an accident, it could very likely have been replaced with one with the hole.
On original fuelies, the air cleaner was bolted to the inner fender skirt. Take a look at the left inner fender, to see if there is any extra holes in it, or any indication that the air cleaner may have been bolted to it.
Generally, all non air small block cars, used the same front spring. If your car is sitting high in front, it likely has new front springs. New aftermarket springs, will often cause the car to sit high. With time and miles, new springs usually "settle" some.
It's also possible that you have the wrong front springs, or the springs aren't seated in the a-arm properly.
Old Apr 6, 2014 | 12:42 PM
Easy Rhino's Avatar
Easy Rhino
Good stuff, guys.
Anybody know the codes for the back side of the instrument panel, and whether or not the codes can be read with an inspection mirror (in other words, without removal)?
Old Apr 6, 2014 | 01:21 PM
5thvet's Avatar
5thvet
The codes are on a sticker on back of cluster so you might be able to see with a mirror but I have not tried. The codes are by horsepower with the highest horsepowers together.
LA - 250 / 300 hp
LB - 365 / 375 / 425 hp
LC - 350 hp
Don
Old Apr 6, 2014 | 01:38 PM
Easy Rhino's Avatar
Easy Rhino
LA - 250 / 300 hp
LC - 350 hp
Don
Thanks, Don.
Old Apr 6, 2014 | 02:47 PM
midstyle's Avatar
midstyle
Thanks, Don.
Should be able to see the sticker on back of cluster if you get your head down around the clutch pedal.
c
Old Apr 6, 2014 | 07:23 PM
Easy Rhino's Avatar
Easy Rhino
c
LB it is.
Old Apr 6, 2014 | 07:38 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
There also is a ink date stamp on the back. If it's still readable it should line up with your cars build date.
Old Apr 6, 2014 | 07:40 PM
Easy Rhino's Avatar
Easy Rhino
XLNT!
This site is great. Tons of knowledgable folks.
Any idea where on the back the ink stamp is?
Old Apr 6, 2014 | 08:23 PM
ricks327's Avatar
ricks327
Here is a photo of the back of my 67 cluster.
Rick
Old Apr 6, 2014 | 08:34 PM
Easy Rhino's Avatar
Easy Rhino
Rick
Thanks!
Old Apr 6, 2014 | 08:43 PM
steveale's Avatar
steveale
Didn't 65 BB cars also have a rear anti sway bar that small block cars did not have?
Old Apr 6, 2014 | 08:50 PM
Nowhere Man
Yes.
To confirming the correct original engine
