63 Split Window VIN?
Old Apr 8, 2014 | 11:02 PM
Duke123's Avatar
Duke123
Cruising
Default 63 Split Window VIN?
Does the VIN on a 63 split window tell you which motor (250, 340HP, etc.) it came with? Here is a picture of the VIN....thanks for your help!
Old Apr 8, 2014 | 11:10 PM
mrtexas's Avatar
mrtexas
No but the trim tag to the left of the VIN does in code.
Old Apr 8, 2014 | 11:27 PM
Duke123's Avatar
Duke123
Cruising
Here's the trim tag....
Old Apr 8, 2014 | 11:34 PM
vintagecorvette's Avatar
vintagecorvette
The trim tag will not tell you what engine the car came with.
Old Apr 8, 2014 | 11:36 PM
Duke123's Avatar
Duke123
Cruising
Sorry....
Old Apr 9, 2014 | 04:10 AM
GKO777's Avatar
GKO777
Sorry....
You need to look at the engine stamp pad. Mine is F0523RD, RD stands for 300 HP, RC for 250 HP. Stamp pad is found on the front right side of the engine.
Old Apr 9, 2014 | 06:45 AM
MaineDoc's Avatar
MaineDoc
I suspect that the OP is missing the original engine. The simple answer is that no, without the original engine there is no way to tell what the original engine was. One possible exception is that there are some signs to strongly suggest if a fuel injection engine was there. No records of this exist at GM, or at least none have surfaced so far.
Old Apr 9, 2014 | 06:50 AM
Easy Rhino's Avatar
Easy Rhino
From: Middle TN by way of KY, OH, VA, IL, CA, FL, NY, SC, HI
^This^
Neither the VIN nor the trim tag identify the engine.
However, if the engine is original, it will have the last several digits of the VIN on the engine stamp pad.
If the engine does not have the partial VIN on the stamp pad, it is not the original, and one is left to do some forensics in an effort to try to ascertain what the original engine was, e.g., does it have the high rpm tach and the high oil pressure gage, evidence of removed badges on the fenders, evidence of fuel lines specific to a particular engine, etc.
Good Luck!
I do like the low VIN on that car, however.
Old Apr 9, 2014 | 09:07 AM
ifitgoesfast's Avatar
ifitgoesfast
I'd say no, unless GM made a 837 big block engine back then.
STYLE 63 837
TRIM 490J
Old Apr 9, 2014 | 09:15 AM
GKO777's Avatar
GKO777
STYLE 63 837
TRIM 490J
An 837, that should have given it a few extra HP
The 837 stands for 'coupe', 867 for 'convertible'...
Old Apr 9, 2014 | 09:22 AM
ifitgoesfast
Yeah, forgot to use the appropriate emoticon
Old Apr 9, 2014 | 09:35 AM
Geralds57's Avatar
Geralds57
2024 C1 of the Year Winner - Modified
2023 C1 of the Year Finalist - Modified
2022 C1 of the Year Finalist - Modified
2020 C1 of the Year Finalist - Modified
2019 C1 of Year Finalist (performance mods)
2018 C1 of Year Finalist
From the trim tag it should be Silver Blue with dark Blue interior. Body assembly date G4 (March 4). VIN 11093 build date March 20.
Old Apr 9, 2014 | 12:20 PM
vettebuyer6369's Avatar
vettebuyer6369
Just remember its easy to add a lot of those parts. One common mistake some people make is they see the radiator support with the "hole" for the FI setup and assume the car was a FI car. People commonly bought this part as a dealer replacement part over the counter. It came with the hole to fit everything, but in the car they mislead some people.
Old Apr 10, 2014 | 10:51 AM
JohnZ's Avatar
JohnZ
On a '63, the body build date format shows the WEEK of the month, not the DAY of the month as '64-up did; G4 for this car is the 4th week of March.
To 63 Split Window VIN?
