hooking up remote starter
Old Apr 12, 2014 | 07:18 PM
LT1driver's Avatar
LT1driver
Default hooking up remote starter
I should know but have forgotten, getting old I guess. so where do you hook up wires at the starter and is there any place besides on the starter that is easier to get to???? this on c2
Old Apr 12, 2014 | 07:37 PM
Powershift's Avatar
Powershift
One lead on the battery (+) connection to the starter and the other lead to the "S" terminal (with purple wire).
A word of caution per the 1967 Chevrolet Service Manual: "Whenever the engine is cranked remotely at the starter, with a special jumper cable or other means, the primary distributer lead must be disconnected from the negative post on the coil and the ignition switch must be in the ON position. Failure to do this will result in a damaged grounding circuit in the ignition switch." (Section 6M-11 ENGINE FUEL)
Larry
Old Apr 13, 2014 | 06:34 AM
MikeM's Avatar
MikeM
...... and is there any place besides on the starter that is easier to get to???? this on c2
You have a male/female hardshell connection in the engine harness about in line with the wiper motor. You can pull the tape back and tap in there to the end going to the starter.
Old Apr 13, 2014 | 12:10 PM
Michael H's Avatar
Michael H
That male / female hardshell connection near the windshield wiper motor connects a purple / violet to another of same color. On Automatic cars, these connections don't connect to each other, they connect to the neutral safety switch down on the tranny.
Old Apr 13, 2014 | 02:04 PM
JohnZ's Avatar
JohnZ
That's true for '63-'64 Powerglides - for '65-'67, the Powerglide neutral safety switch is INSIDE the car, on the shifter handle mechanism.
Old Apr 13, 2014 | 02:46 PM
MikeM's Avatar
MikeM
Neverrtheless, the hardshell connector is there on all midyears and you can use it to tap in for a remote starter, even SWC's and L 88's.
To hooking up remote starter
